Old 04-23-2008, 01:01 PM
Cinci_State_01 is on a distinguished road
I need some help with an Emco PC Mill 125
I am a new user that needs some help. I just happened to stumble on this forum from some google searching and figured there's some experts here that can help.
I am a student at Cincinnati State Technical College in Cincinnati, OH and we are working on a special project. We currently have an Emco PC Mill 125 that we use for CNC programming classes. We mostly machine blocks of machining wax with the occasional steel and aluminum parts. For this project we are trying to add two options:
1. An air system that lets us have a continuous stream of air blowing on our part to clean off chips when we machine the wax (working similar to the way a coolant system works).
2. A coolant system.
Does anyone know if there are any kits or easily available parts to make these work with the mill we have? Also, does anyone know where we can get a service manual or schematics so we can track down what is already installed and set-up in this machine? Any help or guidance will be greatly appreciated.
Old 04-23-2008, 03:50 PM
jalessi's Avatar
jalessi is on a distinguished road
Emco
Hope this helps.
Emco software link:
http://www.mediafire.com/?79n9xj09cos
Spray Mist Unit
http://tinyurl.com/3o622b
Vortex tube:
http://tinyurl.com/4yxm3z
There are a lot of mills like yours retrofitted to run Mach III, the retrofit is not very difficult.
Jeff Alessi
jalessi@aol.com
Old 05-05-2008, 10:13 PM
I am looking more for how i can find things out about my particular machine. After some research my class mate and I found a coolant system and pneumatic valves to piece together our two systems. Now our only problem/issue is how are we gonna work it. We would like to use any pre-programmed input/outputs already in the machine so we can turn the systems on and off w/ the M-code. Does anyone know of someone I can call or get in touch with that could help? I've called Emco and they said that they would have to send out a service guy for $1000 a day and MAYBE he could tell us what we have but we don't have that kind of money to spend on a service call.
Thanks.
emco pc mill 50 & similar hutchison Benchtop Machines 176 Yesterday 06:42 AM
Help with Emco F1 mill svon89 Benchtop Machines 14 06-06-2010 05:54 AM
Need Help!- Emco PC mill 50 Madog-Mitchell Benchtop Machines 1 11-10-2009 06:34 AM
Emco PC Mill 30 Questions lanb Benchtop Machines 1 09-24-2007 01:00 AM
Emco-Maier PC Mill 30 txcowdog General CNC (Mill and Lathe) Control Software (NC) 0 07-28-2005 11:18 AM
