  #13
Old 04-24-2008, 04:53 PM
Al_The_Man's Avatar
Originally Posted by bilinghm View Post
They list all the variations of the X2 style machines, each has the same wattage rating on the motor: 350, but the stated HP goes from 4/5 HP for Harbor Freight, to 3/4HP for Grizzly, and .47 HP for Micro Mark. Little Machine Shop sells the replacement motor that fits them all, and it is rated 350 watts. Is there a 550 watt replacement motor out there for the X2?
I think someone is playing with numbers!
Upfront, I do not have personal experience with the X2, but I think if I was replacing a 1 ph motor, economically, I would be looking at the DC motors available, either ex treadmill type or surplus DC servo, with a SCR controller from KB or Baldor. no power supply needed!
Or a 3 phase motor with a VFD, 220 1ph input.
One you get into AC servo, the controller gets a bit more specific and less flexible.
  #14   Ban this user!
Old 04-24-2008, 07:16 PM
Stepper Monkey is on a distinguished road
I don't know how they would stack up against the stock X2 motor. I have only been using them as lighter replacements for the stock Taig motors, which are only a 1/4 HP, so they really do the trick there.
Don't know if there would be a lot of benefit against the X2 motor though. Guess someone would have to try it. I know brushless are more efficient, so more power delivered for the same wattage draw, but by how much exactly I don't know. Might be a wash.
Thanks for the PS tips, AL. If there is a cheap way to run these things it would certainly make them a lot more useful to a lot more people as cheaper options than a proper motor and VFD package costs.
  #15   Ban this user!
Old 04-28-2008, 04:16 PM
bilinghm is on a distinguished road
I listened to all this good advice and spent $20 (big spender) on a 90 volt DC brushed motor. It is a Electrocraft 703. The max speed is 4000 RPM, the continuous torque is 410 in/oz, and it seems like (if I am reading the chart correctly) the amps are 7.7. See the catalog with the specifications here: http://www.electrocraft.com/files/el...aft_legacy.pdf
Questions: Does this look like a potential spindle motor? Do you think it will work with the OEM X2 mini mill speed controller?
Using surplus servo motors as spindle drive Swede Servo Motors and Drives 11 03-16-2008 08:05 AM
Can I use these brushless motors? runinbymdnt Servo Motors and Drives 2 10-04-2006 09:46 AM
Brushless DC servos VS. Brushless R/C motors sp1nm0nkey Servo Motors and Drives 1 03-07-2006 09:37 AM
can brushless drive drive brushed motors ? max_imum2000 Servo Motors and Drives 2 02-09-2006 07:35 AM
Brushless spindle drive using Stevie Servo Motors and Drives 9 02-03-2006 08:57 PM
