| "High speed machining" on the CNC X2... After watching plenty of videos of industrial setups running at crazy feed rates but quite shallow cut depths, I thought I would give it a try on the X2. I was surprised at how effective it was, achieving over double the removal rate I was getting on my 'normal' roughing strategy. The finish is excellent too. NORMAL: Depth of cut 0.8mm Feed rate 100mm/min HSM METHOD: Depth of cut 0.2mm Feed rate 1000mm/min I run a Proxxon IB-E spindle at 20,000 RPM with a 2mm solid carbide 2-flute cutter. The only coolant is an air blast. I also used a 500mm/min 10 degree ramping plunge instead of a straight plunge at 50mm/min. The only downside I can see is greater machine wear. |
| that is simply wonderful to see in operation. Hope to have mine run just like that sooner than later! |
| Thats awesome! Really neat, I likey |
| Thanks. I will definitely be using this strategy in the future whenever I run this spindle. It puts much less load on the Proxxon motor and bearings. |
| Has anyone tried any other roughing method? Like trochoidal milling? |
| "low end" HF Spindle or "high end" router for about $1000? | biomed_eng | DIY-CNC Router Table Machines | 14 | 01-06-2012 01:15 AM |
| has anyone got experience with "speed demon" linear guides? | MatD | Linear and Rotary Motion | 10 | 01-18-2008 12:47 PM |
| High feed endmills "Feedmills" | MDLang | General Metalwork Discussion | 11 | 06-30-2007 04:16 AM |
| 1.5" Dia High Speed hanging 6" | Machine1 | Hard and High Speed Machining | 5 | 05-25-2004 03:43 AM |
| min speed exceeds max speed for axis "x"? | ljoe1969 | TurboCNC | 4 | 01-19-2004 08:49 AM |
