Old 04-16-2008, 09:59 PM
pete from TN's Avatar
pete from TN is on a distinguished road
Anyone using the ballscrews available from homeshopcnc.com?
I just found their site and they look pretty good and the price does not seem to be all that high. I want to use some 3/4 inch screws on my Lathemaster but I cannot tell which dimension is the od of the screw itself. Anyone got any ideas? Peace guys...
Pete Matos
Matospeter@charter.net
865-363-9218
Old 04-16-2008, 10:34 PM
cadmonkey's Avatar
cadmonkey is on a distinguished road
Well the one's they're using now are 16mm ball circle - basically the same as a 5/8" screw with a 5mm lead - similar to .2". I almost used them but the size of the nut was too big for the X3 according to my solid model and I didn't want to go grinding on the nut body especially since they're internal return types. If they'll fit your application go for it and let us know. I haven't read much about the new screws except for the one email I exchanged with them that the root diameter is actually 12.9mm (a hair over 1/2") - surprised they haven't fixed that misprint yet...
I ended up going with Nook Precision Rolled XPR screws, with the lower grade cut nut @ $30 each (the ground nuts are about 10x as much) double nut on the X and preloaded the balls on Y - I'm going to get their adjustable preload nut and flange for the Z when I finalize that design - price for that is about the same as the homeshop nuts for the current screws. I did my own screw machining (it's not as hard as many think if you have the equipment and ingenuity to make what ya got work).
Every day is a learning process, whether you remember yesterday or not is the hard part.
www.distinctperspectives.com
Old 04-17-2008, 11:37 AM
acondit's Avatar
acondit is on a distinguished road
Cadmonkey,
Where did you find the Nook XPR screws?
Alan
http://www.alansmachineworks.com
Old 04-17-2008, 01:07 PM
cadmonkey's Avatar
www.nookindustries.com you can request a catalog and they'll send it free (and quick) and then you can do a request for quote over their website. The website has an interactive catalog (no prices) and you can download 2D & 3D cad models in a variety of formats - I verified my design fits before spending a penny and didn't have to draw any of the possible solutions. Very handy. I forget what I paid per foot for the screw, but it was very competitive with others and then cut the 6' stock length with a cutoff wheel on my angle grinder. The woman I traded emails with getting the right parts (as I was SHOCKED at the cost of the nuts I originally designed around) was very helpful and responded to questions quickly and in depth.
Still - I'd like to see some people who've gone out on a limb and gotten the new homeshop screws - I have future projects which their offerings might be well suited for. Not trying to bash them by any means. They used to carry the Nooks so that's what I started designing around then they stopped the Nooks and went to their own screws.
HTH
Old 04-17-2008, 03:02 PM
sergizmo is on a distinguished road
I am designing a small mill around the homeshopscnc screws. They offer machining services which was a big factor in picking them. I can't machine the screws at home. Another was the internally ground nuts preloaded to zero/almost zero backlash. No need for two nuts on each screw.
The calculated cost for three screws with nuts, three fixed end support, one free end support, and all machining was just under $1,100. Ready to go, no work required. Not bad at all for a set of what appear to be quality drop in screws with supports. I figure this is about as good as it gets quality wise for a rolled screw setup, and a ground one ready to go would be in the $2,500 plus range.
I just wish they carried some smaller linear guides.
Serge
Old 04-17-2008, 08:15 PM
Jeez $1100.00, I was hoping it was around $400.00 for my setup....
Of course I will not be needing the end supports and I will be machining my own screw stock. I think I wanna go with some 3/4" screws with sero backlash nuts rolled screw stock for all three axes. Just dunno is $400.00 will cover all that. I think they said the Homecnc screws was like $1.98 per inch and the nuts were like a hundred each. Lesse here, x is prolly around 34, y is like 16 and z is like 36 which comes to around $170.00 plus shipping plus three nuts at $300.00 oh well so much for my $400.00 huh. And those are not even 5/8 inch screws you say. I think I will check out the nook catalog you mentioned, anyone else have some input on this? Thanks all....peace...
Pete Matos
865-363-9218
Old 04-17-2008, 09:44 PM
lgalla's Avatar
lgalla is on a distinguished road
Reid Supply has Nook and Thomson with good online pricing
Larry
L GALILEO THE EPOXY SURFACE PLATE IS FLAT
Old 04-17-2008, 09:54 PM
cadmonkey's Avatar
You can definitely stay under the 1k mark. My order for 6' of screw (enough for my x,y and z) three nuts (enough for x and y) was right around $300. Add the Z preloaded nut and a mounting plate for it and my screw related total will be right around $500. Toss in some wipers since I didn't get them the first trip around and maybe I hit $600. Add the Al stock and misc bearings and hardware and my mechanical portion of the conversion is under $700 even if I get the wipers.
Self machined the ends though - it would've been hell to make Homeshop's end blocks work around my table's dimensions...
And Serge - we of course expect pictures when you get the machine built
That reminds me I need to start prepping my pics...too many tasks, not enough hours...
Old 04-17-2008, 11:39 PM
Yeah guys that cost is for everything. Drop in units. X is supported on both ends and Y and Z on one. Here is the breakdown.
Stock: $1.89 X 48" = $91
Ballnuts: $95 X 3 = $285
Fixed end support: $120 X 3 = $360
Free end support: $55 X 1 = $55
Machining fixed: $85 X 3 = $255
Machining free: $25 X 1 = $25
Total: $1,071 plus shipping and whatever crossing the border costs.
Seeing as my lathe is a Sherline there is no way they are getting machined at home. Paying a job shop would be just as expensive (I don't have any hook ups) and there is a risk it may not be a good fit for the supports. Having homeshopcnc machine them assures that they will fit the blocks properly.
cadmonkey: It will be a little while before I start building. Still CAD drawing the machine (on second design), and I need to launch the business and start selling putters to get the cash needed. Once the cash is in hand building this mill will be priority #1, my Sherlines won't last long.
The base is a 18 by 12 by 3 granite surface plate drilled for steel inserts. The base components will be screwed into tapped holes in the inserts (Risers for rails, end plate, column, etc...) and an angle plate will be used to help support the column. Structural parts will be aluminum. Will be using aluminum putty to get parts really flat and reduce machining time. An X2 R8 spindle box with the belt drive conversion and Tormach tooling system will be used. Thinking about a DC motor with one of those dimmer switch type speed controls in the 3/4HP range. Looking at a Keling ready built contol box (The more powerful one) and steppers from them as well. Also will go with flood coolant and an enclosure. Might use with limit switches, but not for a while. Mach 3 will be the control. Hope to be in the $5,000 total range including absolutely everything (including Tormach tooling).
When it's well under way there will be a thread in the building log forum.
Serge
Old 04-18-2008, 06:23 AM
cadmonkey's Avatar
I think I've seen you mention that setup before (or someone with something similar) - I recall the cringing of people thinking about drilling their precious granite plates Good luck! I'm itching to finish mine but looks like this weekend will be doing work for/with the landlord renovating the kitchen ceiling and soffit walls. Since he isn't as adept at drywall I've got my work cut out for me on that...especially since it's a 2 piece suspended drywall system...in section an inverted U with an inverted fat T supported on threaded rod with lighting on top and bottom of the T... It'll look fantastic when completed but it's gonna be a female dog...
  #11   Ban this user!
Old 04-18-2008, 06:28 AM
RotarySMP's Avatar
RotarySMP is on a distinguished road
Precious granite plate? Mine is an 18x12x3 grade A (at least that is what the "quality certificate" says) and it cost me something like $19 from Shars.
I have been thinking of making a whole mill frame out of these cheap chinese surface plates.
Regards,
Mark
www.wrathall.com
  #12   Ban this user!
Old 04-18-2008, 10:49 AM
Bird_E is on a distinguished road
Go with 3/4"
Pete,
I woud go with 3/4" screws. The 5/8 are perfect for the X3 and smaller machines. but the RF45 needs a little more.
Also, Check www.mcmaster.com
The have screws and nuts as well.
bob
No more nook ballscrews from homeshopcnc LazyMan DIY-CNC Router Table Machines 30 07-09-2011 06:49 PM
homeshopcnc HF Spindle jeb DIY-CNC Router Table Machines 11 04-08-2008 07:56 PM
Anybody tried homeshopcnc.com ballscrews on a Joecnc2006? Shev Joes CNC Model 2006 2 01-10-2008 01:39 PM
G203V - HomeShopCNC ccsparky Gecko Drives 2 04-03-2007 07:35 PM
Ballscrews on E Bay mxtras Linear and Rotary Motion 0 09-07-2005 03:50 PM
