Old 04-16-2008, 01:22 AM
andersbrun is on a distinguished road
Terco CNC 45
Hello
I just got a Terco CNC 45 at house, and that's about it. I miss manuals, and everything else. I also miss one cable from the controllerbox to the mill....it's a cable a bit wider than a parallell port cable (will post a pictur later)
I would like to gather as much information as possible for this mill, and hopefully get started in a while!
Here is a picture of it
Name:	cnc terco45.jpg‎
Old 04-16-2008, 01:50 AM
jalessi's Avatar
jalessi is on a distinguished road
terco
Terco has been out off business for a long time.
You may have to retrofit your mill with new stepper motors and driver-controller.
Doing a retrofit will also enhance the machine tenfold.
Gecko is coming out with a inexpensive drive and finding new steppers wont be a problem.
Mach 3 is also inexpensive and works very well.
Then you have to chose a cad cam program.
There are several Terco owners here and I am sure they will help out.
Jeff Alessi
Old 04-22-2008, 02:49 PM
thanks for the hints......i'm not sure about the steppers. What would i look for to make the descission about changing these?
I guess i need a new driver controller to control the mill from a std computer?
Anders B
Old 04-22-2008, 03:10 PM
jalessi's Avatar
Steppers and Stepper Driver
Anders,
Gecko is in the process of introducing a new stepper driver that is very good and very affordable, see the attached link:
http://www.cnczone.com/forums/showthread.php?t=51083
It is a long read however it will save you some money for sure.
As far as steppers go any brand that is 2 phase with 250 oz/inch and larger should work very well.
You can purchase new ones from Keling or several other vendors see list:
http://www.kelinginc.net/StepperMotor.html
http://www.hobbycnc.com/products/stepper-motors/
http://tinyurl.com/5ph38m
The vexta products are going to be very expensive.
Hope this gives you some direction.
Jeff Alessi
Terco 45(00) mill amo General CNC (Mill and Lathe) Control Software (NC) 2 06-27-2011 03:43 PM
Terco 45(00) amo Software Products 1 09-03-2009 03:29 AM
What is a Terco? grinderdust Benchtop Machines 8 01-23-2007 01:21 PM
