Old 04-05-2008, 12:24 AM
Oldboy is on a distinguished road
Any one have this problem befor with there X2?
I was making chips on some cast iron for a few hours.
Sure motor got HOT. Next thing happen motor had a dead stop.
My first thought was the cheap plastic gears broke and jam-up the motor.
Well after taking apart the X2. Not one Tooth busted. Gears are ok.
The problem is the cheap-ass plastic motor bell front cap broke.
Then since motor had NO support on the front bearing the motor armiture took out some of the out side magnet. This stop the motor dead in its tracks.
So looks like LMS sells a replacement #2573 Motor Bell Front.
I was going to do a mod with a Treadmill motor. Just did not want to do it just yet. Need to get some more work out of the old X2 motor.
Old 04-05-2008, 11:33 AM
blades is on a distinguished road
Looks like I'll be keeping an eye out for a treadmill motor!
Speaking of this, anyone who has done this mod, did you replace the speed controller also when you replaced the motor?
Old 04-05-2008, 12:32 PM
http://cgi.ebay.com/New-130-VDC-2-5-...QQcmdZViewItem
http://www.surpluscenter.com/item.as...tname=electric
I purchase TWO of these motors. One for the CNC X2 MOD Mill im bulding.
"Explains the CAST IRON MILLING".
And one Motor for a Mod Lathe; "Next project after the Mill".
I have not purchase the Speed control.
But the one I listed is what I will use with the Treadmill Motors.
The motors are very heavy. Look powerfull.
I cant remember but someone on this form did mod there X2 with the same Treadmill motor. May be they could post some photos?
Im wondering if the original X2 Power Controler would have the Amps-DC Volts to power the treadmill motors?
Old 04-05-2008, 12:47 PM
I Epoxy the Front Motor Bell Cap last night.
Put it all back together. Started cutting New Dovetails in the X2 Base.
So far its holding. Have to watch the HEAT. Cut a little let it cool,then cut some more. Will Flood Coolant System work on CAST IRON?
Im milling it Dry right now.
Old 04-05-2008, 11:04 PM
I was looking at that very motor on ebay today, wondering if it would be suitable. Sure looks like it would be. Maybe I'll give one a try. I wonder if our existing X2 speed controls would work for this motor? Guess it depens primarily on the current draw thru the controller.
Old 04-05-2008, 11:06 PM
From my limited experience machining cast iron, the material itself didn't really generate that much heat, but I believe flood coolant is perfectly acceptable to use on it.
Old 04-06-2008, 11:16 AM
hoss2006's Avatar
hoss2006 is on a distinguished road
That motor looks like a good deal but notice it does have a max rpm 1500 less
than the stock motor, lots more HP though.
Hoss
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
Old 04-06-2008, 12:23 PM
skip20 is on a distinguished road
Oldboy & HOSS
I got the motor already, its 15lbs 5 more then stock, also it's 4" dia.
1" larger then stock, gave up on that idea & will be using it for 4th axis.
Check my post on Mods to X2 mill spindle, show I used a 2.5HP 90VDC motor that come in at 10lbs same as stock.
Old 04-06-2008, 12:25 PM
On your stock motor check you brushes, my motor got hot & killed the springs. LMS has replacements cheap.
machine problem or software problem? bcnc Syil Products 8 10-26-2009 09:51 AM
Shutting down befor part is finished? Ken_Shea Haas Mills 9 07-31-2003 11:18 PM
