Old 03-29-2008, 10:39 PM
mrcodewiz is on a distinguished road
Hoss Conversion Well Under Way
I turned the ball screws a couple weeks ago but didn't have a chance to do much else until today. I don't have a boring head so a lot of stuff went from the mill to the lathe to make the pockets and through holes the right size.... I have all the flat stuff done. Tomorrow I'll start on the round stuff.
I am planning on finishing the Z-axis ballscrew mount once I get the conversion done as I cant fit it on my lathe and its too big for my rotary table so I have no way to make the pocket.
I messed up the left brace a little but it turns out my mill must not be made the same as Hoss'? I have this bar that runs down the side with a ruler on it (see next pic)
Old 03-29-2008, 10:48 PM
tooManyHobbies is on a distinguished road
Looks like a good start!
Whose ball screws did you buy?
tom
Old 03-29-2008, 10:53 PM
They are the Rotons. I read the pros and cons of them vs. others but I'm hoping they are good enough. I'll find out once I get it together - worst case I guess I put in different screws later.
Old 03-30-2008, 03:15 AM
tauntdesigns's Avatar
tauntdesigns is on a distinguished road
Nice lathe work!
How was the turning of the ballscrews, easy...... hard?
I'm starting on some tomorrow (X and Z axis) for my lathe conversion.
Did you thread them on a lathe or use a die?
Again, Nice Work!
Jack
Walking is highly over-rated
Old 03-30-2008, 06:40 AM
I cheated. I annealed the ends first. I should have taken a picture but I got a tall bucket and rigged up a way to stand the ballscrew on end inside. I then filled the bucket with water right up to the point that the threading started, heated it to bright red, and slowly let it cool. It cut like butter after that - I went through a several inserts before I decided to anneal them.
Oh and I forgot to mention - I bought the stock kit from Hoss. That was one thing that was holding me back for a while - trying to source all of that. So thanks again, Hoss.
Old 03-30-2008, 12:38 PM
Thanks for the tip,
I don't have a bucket that tall......... I may try to wrap the screw with wet rags and then heat the end. If that doesn't work, I'll hunt down a bucket/barrel for the job.
Thanks again for the tip,
Jack
P.S. I ground down a ring around the screw stock and then tried to cut it with a bandsaw. The screw just laughed at that, 'poor little saw'.
Old 03-30-2008, 03:38 PM
cadmonkey's Avatar
cadmonkey is on a distinguished road
I made a mount to run my angle grinder (pneumatic) on my lathe and kind of an IV drip of cutting fluid and ground to just below the threads. Once you're through the case hardening, they don't cut too bad. I was able to square up the shoulders nicely with a trashed threading bit (I use brazed toolbits till I get around to getting a quickchange toolpost) and the rest was pretty straightforward.
The one advantage is that you'll end up with a harder end to clamp onto the stepper with than if you anneal it.
Every day is a learning process, whether you remember yesterday or not is the hard part.
www.distinctperspectives.com
Old 03-31-2008, 09:08 AM
That's what I want to use too. Let us know how they work out!
Are you following the conversion exactly or are you changing it any way?
I want to go this route too, but I don't have access to a lathe for the parts that need one. I'm gonna check out the machinist we use at work.
tom
Old 03-31-2008, 10:20 AM
tom
I am pretty much following it to a T. If you have a boring head, you may be able to do everything on the mill (except for the ballscrews themselves). I mainly used the lathe to bore the holes to size since I don't have a boring head.
Old 03-31-2008, 10:28 AM
I finished all of the round stuff (except for the stepper handles) and got the X/Y assembled. Hopefully I will test it with the PC tonight.
Man, I need a better camera - the phone camera doesn't work too well.
Setup for cutting the ballnut corners down:
Halfway there
X/Y steppers on
  #11   Ban this user!
Old 03-31-2008, 11:56 AM
I'm not sure I'd tackle the ball screws even if I did have a lathe! I'm too new at this!
I want to get a boring head anyway, so might as well do it now. (I still haven't received my X2 from HF!) But I couldn't use a mill for the upper and lower Z flanges, could I?
tom (who hates being a newb!)
  #12   Ban this user!
Old 03-31-2008, 02:03 PM
Z flanges?
Hoss ATC Project hoss2006 Benchtop Machines 285 10-23-2010 08:16 AM
Hoss Mill Console Project hoss2006 Benchtop Machines 91 09-11-2010 03:45 AM
X2 Hoss X Axis mod Question Hellbringer Benchtop Machines 2 03-19-2008 07:20 PM
Hey Hoss! Check your website! tooManyHobbies Benchtop Machines 3 02-26-2008 01:58 PM
Hoss CNC Conversion material cost? mrcodewiz Benchtop Machines 15 01-17-2008 04:41 PM
