Old 03-27-2008, 10:33 PM
captainlee's Avatar
captainlee is an unknown quantity at this point
Has anyone mounted a dial I on a mill head?
I would like to mount a dial indicator on the head of my HF mill head to read the depth of cut. Has any one done this if so Can I see the mod??
Thanks in Advance Cap.
Don't Give Up The Ship !!!
Old 03-27-2008, 11:12 PM
CNCRim's Avatar
Sure can... but there is a draw back with dial indicator. 2" range you need 4" clearance, I don't know what your application but if you are part travel more than 3" I say you need something else.
Old 03-28-2008, 06:54 AM
Andre' B is on a distinguished road
I put a 2" travel indicator on the quill of an RF-30, and find it very useful.
First thing I did was remove most of that big clunky depth stop crap they had on it, also the plastic front cover. Just made a little al. bracket to hold the indicator. I think I had to file a flat spot on the casting to mount the bracket so it was parallel with the travel.
I will get a pic but will not be able to post it until Monday.
Old 03-28-2008, 12:17 PM
captainlee's Avatar
Hi Andre'B,
Thanks for responding I will be waiting for your picture this is just what I need.
T H A N K S. Cap.
Old 03-28-2008, 12:26 PM
mrcodewiz is on a distinguished road
I made a simple mount but it mounts to the column instead of the head. I will upload a pic tonight.
cam1 is on a distinguished road
You could also opt to mount a 6 inch Quill DRO. Nice to have a floating Zero, and inch/metric display.
regards
Old 03-28-2008, 03:41 PM
Pictures aren't the best but here is what I use. Took about 5 minutes to make on the lathe... the clamp was stolen from one of those caliper sets that come with the magnetic base.
ID:	56524   Click image for larger version
ID:	56525   Click image for larger version
Old 03-28-2008, 06:37 PM
captainlee's Avatar
Thumbs up
MRCODEWIZ, Hello
Thank You for those great pics you really did a great job. I like the fact you made a bracket that is removable and won't create any holes on your mill.
Well thanks for the food for thought I'm going to wait and see other ideas and I'll start on this in a few days. I will post the result somewhere for anyone to see whois interested tks Cap.
Old 03-28-2008, 06:46 PM
captainlee's Avatar
Cam1 Hello,
Yea I bought two large dial indicators from HF and some on ebay, So I want to use them
so 1 will go on the mill head as soon as I get the right configeration and plan to fit my
machine. T H A N K S for your input. Cap.
Old 03-28-2008, 06:50 PM
blackbeard52 is on a distinguished road
I saw a mod made from a $14 dial caliper very simular to this.
  #11   Ban this user!
Old 03-28-2008, 07:04 PM
I have been using my dial indicator for years and it has worked fine. I installed X and Y digital scales and a DRO about a year ago because setting up the indicator on X,Y tends to be a bigger pain because the travel is usually much further. I am just now installing the digital scale on the Z axis because grizzly had a 12" vertical scale for $50 (couldnt find them for less than 100 back when I did the X,Y).
This scale is the deal of the century in my opinion.
http://grizzly.com/products/12-Digital-Scale/H8134
  #12   Ban this user!
Old 03-31-2008, 08:23 AM
Here are some pics of my little setup.
ID:	56673   Click image for larger version
ID:	56674   Click image for larger version
ID:	56675   Click image for larger version
Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head fignoggle Benchtop Machines 18 05-11-2009 11:11 PM
Tramming the ST mill head dahui Shopmaster/Shoptask 4 03-24-2007 03:29 AM
Mill head MrRage Benchtop Machines 4 11-06-2005 02:20 PM
Which milling head for a little mill ? pigifly General Metal Working Machines 12 06-20-2004 05:02 PM
An end mill for your head nervis1 CNCzone Club House 4 05-25-2004 01:57 AM
