Old 03-26-2008, 09:05 PM
tikka308 is on a distinguished road
Blanking...
What's it called when material (e.g. aluminum) builds up between the flutes? For some reason the term is eluding me...
Tormach PCNC 1100, SprutCAM, Alibre CAD
Old 03-27-2008, 12:34 AM
tauntdesigns's Avatar
tauntdesigns is on a distinguished road
Galded
not sure how it's spelled
Walking is highly over-rated
Old 03-27-2008, 01:38 AM
Stepper Monkey is on a distinguished road
Galling is the term you are looking for I think.
Some aluminum alloys like to do that, some of them are downright gummy. You aren't trying to machine on "found" aluminum are you? If so, just try again on a known alloy designed to be machinable. Some aluminum alloys out there are just not practically possible to machine no matter what you try to use on it.
Old 03-27-2008, 07:44 AM
No, I'm using 6061 from speedymetals.com. I just ran it too long without coolant and the part got really hot - definitely my fault.
Galling huh? I was thinking the term was "chip welding"
Old 03-27-2008, 11:49 AM
blades is on a distinguished road
Galling is the result of what it does to your surface finish. The material build-up on the end mill was always refered to as "loading up" when I was machining for a living.
When machining aluminum, I used to use a 50%-50% mix of thread-cutting oil and mineral spirits. Always made for a nice surface finish as well. An oil-based cutting fluid will help prevent gummy aluminum from sticking to the end mill more so than a water-based coolant. Of course this may not be practical if you have a dedicated coolant return system in place on your mill.
