Old 03-24-2008, 07:56 PM
blades is on a distinguished road
X2 Timing Belt drive (cheap, of course!)
El Cheapo strikes again! This time around it's an inexpensive belt drive. I've got about $40 into the 2 pulleys & 2 belts (one spare).
The beauty of this project is it's simplicity. The 18 tooth spindle pulley has a hub diameter and overall length nearly identical to that of the upper spindle spacer on the X2. The only modification required was a 30mm bore with a 5mm keyway. Thanks to Toyota for being the unoffical sponsor of this modification. The mill work is a bit rough on the aluminum. Most of it was done by hand & on a small drill press. I will probably end up making a nicer piece with better dimensional accuracy than this one. But for now, it serves the purpose and seems to work quite well. Also forthcoming is some sort of integrated spindle lock, since I obviously lost it with this mod.
Old 03-24-2008, 08:04 PM
Regnar's Avatar
Regnar is on a distinguished road
Nice Job. Especially for 40 bucks. Now we need a Video!
Old 03-24-2008, 08:51 PM
mrcodewiz is on a distinguished road
Nice Work! That is a nice simple design. One big difference between yours and others I have seen is the toothed pulleys instead of the V pulleys. Yours won't allow for any slipping - you may want to put some sort of cover over the exposed belt - No idea what might happen if you lock up the spindle. Wouldn't want to see it break and fly off at you.
Old 03-24-2008, 09:20 PM
Oldboy is on a distinguished road
Very nice!
blades could you tell us the P/N & where to get the Parts?
What RPM you get out of that set up?
Old 03-24-2008, 09:44 PM
pzzamakr1980 is on a distinguished road
I purchased my belts and pulleys from quality transmission components. They have ads all over cnczone. SPDI is also great, and they have a better selection.
Old 03-25-2008, 01:24 AM
kanton's Avatar
kanton is on a distinguished road
Part numbers and addresses would be helpful.
Old 03-25-2008, 05:16 AM
LeeWay's Avatar
LeeWay is on a distinguished road
This looks great. I too am looking for the pulleys. I already have the Steele belt conversion and have add a large 2HP treadmill motor that I run on 220. It runs about 3800 rpm on the Steele drive in high speed pulley. This motor has loads more torque than the OEM mill motor and I see belt slippage where the original motor would have just stalled.
I looked on SDP and didn't locate anything with a 30 mm bore. I do have a mini lathe, so making the bore a little large will be easy enough.
I have never broached a keyway, but I have thinned down key stock after I moded a pulley bore or I have also installed two set screws into the slot.
I guess I need to learn to broach.
What size bore did you start with?
Thanks.
Lee
Old 03-25-2008, 05:27 AM
digits is on a distinguished road
Thanks.
Broaching is obviously nice and neat, but I have made pretty decent pulley keyways by simply plunge cutting with an endmill and then squaring up with a hand file. As this is just a spindle pulley, you don't have to worry about backlash, so a little keyway slop doesn't really matter IMHO.
BTW, lovely conversion Blades - using that box section is a great idea!
Old 03-25-2008, 09:41 AM
Hey guys, thanks for the comments! For those so inclined to copy this project, here's the P/N's from http://www.sdp-si.com/
12 tooth motor pulley (.500" bore) A 6A 4-12DF05016
18 tooth spindle pulley (.625" bore) A 6A 4-18DF05020
33 tooth belt A 6R 4-033050
This pulley combo gives a 1.5:1 reduction, with a theoretical no-load spindle speed of 4000 RPM. You also lose your lower-end torque with this setup, but this is ok for my intended use of the machine.
Please note that the 12 tooth pulley P/N I have given here is NOT the one that I actually used on this project. The one I used had a 10mm bore. I had a brain-fart, and thought I had measured the motor shaft to be 10mm, but it was actually 9mm. Looking after-the-fact, the pulley was not available with a 9mm bore. I temporarily made a bushing out of 0.5mm shim stock, but will have to get a "real" bushing for it. A .500" bore will make it easier to make your own bushing.
FYI, the P/N of the pulley with the 10mm bore is A 6A 4M12DF12510.
I used a broach because I found out it was available to me, but I had originally planned on just drilling a 5mm hole @ 15mm off center before boring it out to 30mm, then file it square.
Old 09-07-2011, 02:48 AM
BubbleOne's Avatar
BubbleOne is on a distinguished road
That is excellent! I love the use of the rectangular section! I recently bought an X2 kit for my clone, turns out it was not enough of a clone, nothing fits, so I'm selling it lol. Have just today bought some T5 pulleys and a belt, I think I'll use the aluminium section idea you have!
  #11   Ban this user!
Old 03-21-2012, 02:16 AM
nolage is on a distinguished road
Double drag up blast from the past, I apologize in advance.
This belt mod originally used two pulleys, one is then bored out to fit the spindle, the other needed to be shimmed. I found two matching pulleys, both that can be bored out (slightly simpler and more stable then shimming I feel). I found the required belt through SDP.
Does this seem viable? I will post my own thread in reference to this when the materials arrive and I can bore out the pulleys and give this a shot.
L Type Groove Belt 3/8" Pitch 12 Teeth Timing Pulley | eBay
0.84" Width Groove Belt 3/8" Pitch 18 Teeth Timing Pulley | eBay
These seem the same except that they both have space for a 3/4" wide timing belt.
timing belt width? JFettig Benchtop Machines 8 01-28-2010 05:34 PM
HTD timing belt pulley R.thayer General CAM Discussion 1 02-03-2007 12:42 AM
Timing Belt Drive Accurace and Price drewgarth Linear and Rotary Motion 7 07-25-2006 06:13 AM
Timing belt drive jdholbrook Linear and Rotary Motion 1 04-29-2006 03:26 AM
Should you put grease on a timing belt? ynneb DIY-CNC Router Table Machines 5 04-22-2004 08:54 AM
