Old 03-23-2008, 08:01 PM
sgman is on a distinguished road
I need help to convert this BF20 Milling machine
Hello
I am looking for someone who has done a cnc conversion for a BF20 Style milling machine
I purchased this milling machine from Busybee its a CT129
http://busybeetools.ca/cgi-bin/pictu...2&NTITEM=CT129
Steven G
Old 03-24-2008, 02:13 AM
lagfish is on a distinguished road
Hi sgman,
Good to see fellow canucks on board. CNC conversion for all benchtopmills are pretty much the same. Measure the stock bearing mounts. Replace standard bearings with angular contact bearings. Replace stock ACME screws with ballscrews. Replace stock ACME nuts iwth nuts that will fit your ballnuts. A good source for ballscrews and nuts is www.homemachineshop.com. Replace stock bearing mounts with newly machined bearing mounts for angular contact bearings. Mount steppters on your aixs, and there you have it. The hardest thing to do for me was to machine down the ballscrews, as they are Rockwell 56 case hardened.
Need Help!- How to machine an adapter to convert taper shaft to straight kola General Metalwork Discussion 11 07-15-2011 10:39 AM
Sieg X3 vs BF20 Mill CADScott Benchtop Machines 12 06-23-2009 09:35 PM
Converting a BF20 sgman Benchtop Machines 27 03-17-2008 11:12 AM
BF20 or RF25 BMaynard Benchtop Machines 1 08-05-2006 06:31 PM
Choices for machine to convert cspmiata Benchtop Machines 2 04-18-2004 10:53 PM
