Old 03-18-2008, 07:31 PM
BrassBuilder is on a distinguished road
I think my X2 motor is about dead
Subject says it all.
When I turn on my mill, the motor just barely turns and then evidently the breaker kicks in and the mill shuts off. If I let the belt loose (I converted the mill to belt drive), the motor will spin, but as soon as I put any pressure on it, it quits. After a few minutes, it will stay running, but it sounds like it is straining. Eventually (2-3 minutes) it will come up to speed.
IF I need a new motor, any recommendations? There has to be something better than the stock one.
edit: I just went down and tried it after having it sit for about an hour and it started right up. I think I still want to look for a different motor.
Mike
Old 03-18-2008, 08:24 PM
BrendaEM is on a distinguished road
Have you checked the brushes?
I'm pretty sure it's a brushed motor. A brush might be stuck in the brush holder. If you take the brushes out, make sure you mark them it identify where they came from and which orientation they have.
You could probably bring the motor to a repair shop, who will probably-check the brushes and make sure there are not shorts in the commutator.
Old 03-18-2008, 08:26 PM
No...never really thought of checking the brushes. I thought the unit was a sealed unit. I'll have to take a look at that.
Mike
Old 03-18-2008, 10:18 PM
maxboostbusa is on a distinguished road
While you have the brushes out look inside at the Commutator that the brushes ride on. Sometimes they can get glazed up and make a motor act up. Also check the springs on the brushes sometimes the heat kills them and they arent strong enough to keep contact anymore. If all else fails there is a 3 phase/vfd combo or treadmill. I havent tried either on my small mill but am leaning toward a larger treadmill motor and controller for my lathe.
Old 03-19-2008, 04:26 AM
MIKE JEFFERS is on a distinguished road
my x3 did this ,bought new brushes no change ,so asked the helpfull folk at arc eurotrade they tell me that they often get this at this time of year
damp in the motor windings
so i sprayed some wd40 in the motor then left it a wee while blew it out with
an airline and off it went ,if it sits for a week or so it does the same again
also check the earth wire's not shorted to the live ,this wont help either ,mine did
Old 03-19-2008, 09:18 AM
I'll check the brushes tonite if I get some time.
I was almost hoping there was an upgrade to do to the mill if I need to replace the motor. I searched around for "motor replacement" and "motor upgrade" on the site but did not find much.
Mike
Old 03-19-2008, 10:47 AM
LeeWay's Avatar
LeeWay is on a distinguished road
If you just want to have a spare or replace yours, I have a used one you can have fairly cheap. About 1/3 of what a new one would cost you. I would throw in the controller alone if interested.
If you want to upgrade, with a little modification to the pulleys and the motor, you could use a treadmill motor off Ebay and the larger controller from Surplus Center. Thats what I use now on 220 volts though. It's pretty strong. I can no longer bog the motor down.
I think I have links to those on my mill build. http://www.cnczone.com/forums/showthread.php?t=32609
Lee
WTB - Used / Dead Nema 34 stepper Motor harryn Want To Buy...Need help! 0 03-18-2008 11:05 AM
Need Dead Simple CNC gerryv General Metal Working Machines 11 08-03-2007 02:09 PM
Dead Emco Compact 8 Motor itsme General Electronics Discussion 24 09-03-2006 01:14 PM
Is the FROG dead? the4thseal General CNC (Mill and Lathe) Control Software (NC) 5 08-06-2006 11:48 PM
Uh-oh, I think he is dead kong DIY-CNC Router Table Machines 11 05-18-2004 06:20 AM
