Old 03-14-2008, 03:27 PM
Regnar's Avatar
Regnar is on a distinguished road
CNC Fusion Kits
I was just wondering how long it took you guys to get your kits. I have ordered mine and anxiously awaiting its arrival.
Old 03-14-2008, 04:45 PM
tai42's Avatar
tai42 is on a distinguished road
About a week from ordering to receiving the UPS shipping notification. From there it's just a matter of how far from Texas you are.
Old 03-14-2008, 06:56 PM
bilinghm is on a distinguished road
I got order confirmation on 2-24 and it shipped today. They warned me that it might take two weeks to ship. Looking forward!
Old 03-14-2008, 07:48 PM
Regnar's Avatar
Just recieved mine too. I was starting to get alittle worried, I ordered the same day as you Bilinghm. I have already pulled the mill apart and repainted it (red chips where flaking off) cleaned, lubed and planned out for the enclosure. Belt drive will be here Monday and I suspect the kit should be here Wensday or Thursday.
Old 03-19-2008, 08:37 PM
I received my X2 kit today. Pretty impressive. The ball screws look like the fancy ground ones instead of the rolled kind that they are. Very brightly polished. The are extremely smooth running. The preloaded ball nuts are marked Thomson. Now the fun starts!
Old 03-19-2008, 08:49 PM
Regnar's Avatar
Received mine today too. I already have the x and y axis installed and moving. I will probably get to the z on friday due to the fact that tomorrow is our anniversary. Both axis run smooth but I hear a slight grinding noise. Almost like I need to grease them up or something. I also had a scary moment when I noticed that the x axis ballscrew was installed backwards so I actually had to use the cardboard tube. I have had bad experinces with little bearings bouncing all over the garage but the tube made it a piece of cake. Lets see some photos of your setup when your done.
Old 03-19-2008, 09:12 PM
Hmmm, on the X axis, it seems that mine is set up for the stepper to be on the right. Was yours' this way too? I wonder if it makes any difference? The Youtube video shows the stepper on the left. I will post pictures soon of my column bracing and the kit installation. I am going to try and get maximum Y travel. I think 4.5" is possible.
Old 03-20-2008, 04:58 AM
Regnar's Avatar
Just flip it around with the cardboard tube. It was easy. Otherwise you wont get the full length of travel.
Old 03-20-2008, 08:21 PM
Any advice on tightening the nyloc nut on the end of the shaft to pre-load the bearings? I have a hook spanner that fits the nut, but how do you hold the shaft from turning?
Old 03-20-2008, 08:54 PM
Regnar's Avatar
I placed the love joy coupler on the end and inserted the locking bar inbetween the "post" and rested it up against the motor frame. It didnt take much force to tighten them down at all. Infact I tighten one alittle to tight and it wouldnt spin.
I liked you ideal with the endcap but after looking at mine there just isnt enough room for it to fit. I think you will have more room than I do because of your machining of the base. I was able to mount the z axis and move everthing around. Im still learning how to use emc2, but was able to get 70ipm moves but they were short. The y axis could produce those speeds with no problems but the x axis is binding alittle. 50ipm is 100% all the time. Im waiting on delivery of some collets and endmills but I have a tramming problem that I need to get out of the way. My y axis is .007 out of tram and I need to shim put the colum. Have any suggestions on where to shim it up at?
  #11   Ban this user!
Old 03-20-2008, 09:15 PM
I would check that the column is square to the base. If it is square, then the shimming could be between the two pieces of the head. If the column isn't square, then shimming of the column base plate would probably be appropriate.
I will post pictures soon of my column brace arrangement that really helps with tramming.
  #12   Ban this user!
Old 03-21-2008, 03:21 PM
Regnar's Avatar
Im still trying to get the tramming done but its going slow, well that is becuase I have been playing around with x and y axis. I should update and tell you that I was able to get up to 220 IMP before EMC crashed. At this speed you pretty much press the key and let off and its on the otherside of the table. I can get 170 IPM and Emc doesnt crash. Still very impress especially when the table size is so small.
Syil X3 CNC or X3 + CNC Fusion + etc iamscottym Benchtop Machines 8 05-11-2008 05:43 AM
VMWare Fusion for MAC WayneHill Computers and Networking 3 07-24-2007 04:58 PM
CNC Fusion Memran Benchtop Machines 1 04-03-2007 06:20 PM
CNC Fusion kits Redline Benchtop Machines 30 11-01-2006 06:22 PM
CNC kits for Sieg machines. Kits for Micro mill available now. wisp Product Announcements & Manufacturer News 19 12-24-2005 12:12 AM
