Old 03-09-2008, 09:35 PM
maxboostbusa is on a distinguished road
CNC4PC C6 Spindle board problems and others
Ok got my C6 board back in and I'm having difficulty getting it to show any voltage to send to the control board on the X2. Here is the setups.
12vdc 600ma power wall mount power supply. C10 breakout board.
Step hooked to pin 14 (output)
Dir hooked to pin 16 (output)
Gnd hooked to the ground with the powersupply to keep it isolated.
Both jumpers on the board set to opto
My home/limit switches work so the board is getting signal I suspect
Mach 3 setup
-Ports and pins: Motor outputs
spindle motor checked, step pin 16, Dir pin 14, Low active, step & Dir port 2
-Spindle setup: motor control
use spindle motor output and step dir. control checked, PWM base 9
min PWM 10%
-General Parameters: CW delay spinup 2 sec, CCW delay spinup 2 sec,
CW spindown 3 sec, CCW spindown 3 sec.
Motor tuning: steps per 1000, velocity 1500, accel 1000, step pulse 1,
Dir pulse 1
HZ set to 25000
I get .83-.85 vdc output regardless of RPM input in the Program Run Display under spindle speed. The dwell icon flashes
Now for other issues I swapped PC's and the Control worked fine until after the swap. Now when trying to Jog I get a high pitched whine out of the motors, the DRO's move but the motor jumps around a little then stops and makes noise. All axis do the same even with the motors removed. Speed and accel doesnet make any difference. Back to the shop to figure it out maybe. Thanks for any help in advance.
Rick
Old 03-10-2008, 10:28 PM
Ok new update. I disabled everything but the c6 board so I would make sure something else wasent interfearing. Hooked the C6 to pin 8(step) and pin 3(dir) both jumpers set to 1-2 (com=gnd and 2-9 output). Nothing checked in the input or output tabs on Mach 3. Use spindle motor and Step/Dir checked in the spindle setup. 25k hz. When measuring the output voltage from the board I get .85vdc, this is with the following results with pin voltages. The E-stop is the one on Mach Active is with the max pulley rpm being 2000 rpm and inputing that speed and getting the dwell and spindle icon to flash green.
Step pulse 5 Dir pulse 1
Pin 8 voltage at e-stop 5.14v active is .08v
Pin 3 voltage at e-stop .04v active is 5.12v
Pin 8 With the step low active checked I get 0v at e-stop and 5.08v active
Pin 3 with the dir low active checked I get .04v at e-stop and .04v active
Changing the step and dir pulse both to 1
Pin 8 voltage at e-stop is 0v and active is .08v
Pin 3 voltage at e-stop is .04v and active is 5.11v
Pin 8 with step low active checked is 0v at e-stop and 5.08v active
Pin 3 with dir low active checked is 5.12 at e-stop and .04 active
Since voltage is coming and going I would think I am getting signal at the breakout board. I should be set up with step and Dir. pulse at 1 with the step low checked for pin 8 to give 0v at estop and 5.08v at full rpm and pin 3 set to normal (not low active) to get .04v at e-stop and 5.11v at full rpm.
Does any of this sound correct? This thing is about to wear me out not to mention the other issues that I'm going to put in another post. Thanks again.
Rick
Old 03-11-2008, 05:09 PM
Hoss, Bob or anybody using this board please post or Pm me your settings if you can. I even have Auturo at CNC4PC stumped.
Old 03-12-2008, 12:43 PM
hoss2006's Avatar
hoss2006 is on a distinguished road
I was only getting about 1 volt output from the C6 to the motor control board when I first installed it.
One trick that got the C6 to increase the voltage output was to open Motor Tuning in Mach 3
and set the Step Pulse to 15.
It calls for 1-5 but 5 only increased the voltage output a wee bit.
I'm not sure why it worked, nor was Arturo.
I thought it may have been a bad pot on the board but who knows.
Give it a try.
Hoss
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
Old 06-01-2011, 05:48 PM
bigblueshoe is on a distinguished road
Issue with c6, voltage not changing
I was wondering if there is some way to troubleshoot the c6,
I have it connect to c10 but not the the motor controller, but when I try to adjust the voltage, it does not change? Even with a m3 or 4s100-2500 command nothing. I have the settings per jd solutions and cnc4pc, but have I maybe already fried this board? And yes I have it on it's own 12v supply
Thanks for your time.
Noel
CNC4PC multi board krymis General Electronics Discussion 23 07-28-2008 07:49 PM
2020 drive with cnc4pc breakout board najnielkp Servo Drives 4 02-27-2007 11:34 PM
cnc4pc multifunction board Rev 2 jguillen08 General Electronics Discussion 4 01-13-2007 09:27 PM
320's and cnc4pc multifunction board dewme5 Gecko Drives 1 08-16-2006 10:22 AM
cnc4pc relay board question Stuff-Builder General Electronics Discussion 14 03-17-2006 09:17 AM
