Old 03-08-2008, 02:47 PM
amurphysmu is on a distinguished road
X3 Motor Upgrade
I'm planning on buying a 3 phase, 1.5 Hp, TEFC motor and Hitachi VFD to replace the stock motor on my cnc'd X3.
http://www.amazon.com/3450RPM-230-460-C-Face-Baldor-VM3550/dp/B000BATM4Y http://www.amazon.com/3450RPM-230-460-C-Face-Baldor-VM3550/dp/B000BATM4Y
http://www.driveswarehouse.com/Drive...00-015NFU.html
I want to stop using the gearing in the X3, mount the new motor vertically, and directly drive the spindle with an L pitch timing belt and pulleys.
Does anybody have a suggestion for a timming pulley that could easily replace the stock spindle drive gear on the X3?
Old 03-09-2008, 11:56 AM
BrendaEM is on a distinguished road
Will weight be an issue, and balance as the X3s motor mounts on the side of the spindle housing?
Old 03-09-2008, 01:33 PM
pzzamakr1980 is on a distinguished road
Weight will be an issue, especially at the top of the column. But a few shims and it should fix it. Post pics of this mod.
Any belt drive conversion will either require you to make your own spindle drive pulley from scratch, or to turn down the stock spindle gear, and bore a purchased pulley, so you have a nice tight interference fit. Some red loctite will help everything stay tight
Old 03-09-2008, 07:41 PM
cadmonkey's Avatar
cadmonkey is on a distinguished road
Definitely will keep watching this thread. What kind of gear ratio are you looking at? I'd love to get a bit more speed and eliminate the gearbox losses/noise (although I can't say as mine has been anywhere near as noisy as I would have thought).
Good luck!
Old 03-09-2008, 08:20 PM
Cad, if you want to lose a great deal of noise, just do that conversion from the arceurotrade pdf. It's great, and pretty cheap. I did that in tandem with a pulley swap. Changed the motor pulley and the head pulley and now get 6000 in high, 3000 in low. The low is great for anything larger than a 10mm drill, and the high handles a 1/2in endmill at .1 DOC full on cutting a slot without breaking a sweat.
Old 03-14-2008, 10:51 AM
bilinghm is on a distinguished road
Last year I did a VFD 2hp conversion on a round column Enco Mill. I now am able to do all operations in a single belt position. I can go from 100 RPM with a big flycutter on steel, to 2600 RPM at 60 cycles for aluminum. It is possible to go to much higher cycles (90 or more) and get additional speed, but I have avoided that so far.
This conversion transformed the machine. It is quiet, vibration free and powerful. However, quality 3 phase motors that are properly insulated for VFD applications are big and heavy. My 2HP Leeson is at least 50 pounds. This was no problem on the Enco, but you will have to evaluate the weight/fit considerations on an X3. Big HP and VFD would be sweet on an X3!
Bill
Old 05-16-2011, 10:21 AM
billfle is on a distinguished road
I am not sure why you want to change the motor to AC? Many scrap dealers now have used DC motors and variable speed controllers from treadmills. I found 2 X 3hp DC motors recently. Mine cost $16 each and are as new.
regards
Bill
Old 05-16-2011, 10:25 AM
Ps; The two DC motors are variable from zero to 4000 rpm and are 180 volt which makes them suitable for 230 volts AC.
Bill
HF 7x10 motor upgrade? dlenardu Mini Lathe 3 01-28-2008 05:12 AM
Motor upgrade Ang_Panday Bridgeport and Hardinge Mills 2 08-27-2007 05:22 PM
IH mill motor upgrade Randall Industrial Hobbies (Support forum) 13 11-14-2005 02:04 PM
Upgrade Motor for a Sieg X3 CNCadmin General Electronics Discussion 13 06-21-2005 07:14 PM
4x6 bandsaw motor fried, UPGRADE! JFettig General Metal Working Machines 4 06-21-2005 07:12 PM
