Hello, all. Just wanted to show off my little bit of effort over the weekend. http://www.johnbearross.com/prototyper.html Roughing didn't take too long. The finish pass with a 1/32 x 3/16 x 3/32 ball end mill took 34 hours, but I think I was using the wrong strategy. Also, a long-reach ball end from bitsbits is on the future purchase list. Thanks to Nick Carter for getting me addicted to this new venture. Best, John Bear Ross www.johnbearross.com |
| 5 IPM, because I'm having seizing issues in the X axis at higher speeds. Milling strategy was a X, then Y, grid pattern. That's probably why it took so long. I'll try a waterline strategy next time, or the grid pattern with a longer tool (longer length of cut). Best, John Bear Ross |
| After the roughing is done, I often use profile bits and not mills on wax for the finish pass. They speed things up a lot, and they are also available from bitsbits.com. 5 ipm is a hair less than a third of the speed I usually do wax cutting at on a Taig. If you are getting axis seizing while moving that slowly there is definitely something wrong - either with the gibs or similar adjustments, or perhaps your motor/driver matching at those speeds (it might be quieter and smoother at faster speed ranges, or you may even need a different motor setup). In any case, try to aim eventually for 10-15 ipm for wax (I use 400mm/min = 15.7 ipm as a beginning baseline, but then again I've been doing this awhile, too). There is definitely a learning curve to the cut strategies to get it up there and even well beyond, but it isn't too difficult to suss out. After you get the X and Y to the speeds you want, your cut speed will be limited by the ability for Z to reciprocate as fast as you need with that many small elevation changes (i.e. cut speed will be will be limited entirely by the Z acceleration setting). For that the only cure is a lighter Z, therefore a lighter motor, and there are some very light and powerful motors that can replace the monstrously heavy original. You can even just use a simple Nema 23 servo and get better speeds and very nearly the same wattage of cutting power for under a couple of pounds weight. That is some awesome work. Keep it up. I'm glad to see someone is still playing Battletech! |
![]() StepperMonkey, thanks for the info. I'll check my gibs and see what I get. Best, John Bear Ross |
| First milled PCB | Jason Marsha | PCB milling | 36 | 11-18-2008 08:49 PM |
| I need some slots milled in some 14 ga SS. | Jeff Wohlt | Employment Opportunity | 2 | 10-31-2007 05:02 PM |
| Anyone need something turned/milled (manual) | skmetal7 | Employment Opportunity | 2 | 08-03-2007 11:11 AM |
| RFQ Al plate/milled | roninB4 | Employment Opportunity | 8 | 09-07-2006 01:23 PM |
| Never milled but have a project | mikesativa | General Metalwork Discussion | 9 | 03-22-2006 01:24 PM |
