Old 03-03-2008, 09:57 PM
grinderdust is on a distinguished road
Cheap backlash removal. Moglice?
I was reading the post about manual machines with ball screws to eliminate backlash and was slapped by a weird idea. Has anyone tried using Moglice or a similar product on a worn acme nut? I know this is probably crazy and won't work but, imagine if it did! I am sure it would be tricky to apply. maybe it could be forced through a small hole and allowed to dry before (attempting) moving the screw. This would probably work better (if it worked at all) if the threads were large.
I may start a poll to see how many people think I am the one whose screws are loose.
Old 03-03-2008, 10:40 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Sure, there is more than one fella who has cast a new nut from Moglice for their lathe.
Best,
BW
Old 03-08-2008, 08:49 PM
sansbury is on a distinguished road
This would be similar to the way Babbit Bearings were made, so it's not crazy. I think the half nuts on the Gingery lathe are also made by casting them on the screw. That said, given the time to set up the mold and the cost of Moglice, replacing the nut might be both faster and cheaper?
Backlash or motor tuning problem? How do I test for backlash? Brian Queen Mach Mill 8 03-10-2008 03:35 PM
Using Moglice or Similar to Improve your Mill Ways? Oldmanandhistoy Benchtop Machines 20 09-21-2007 08:17 PM
Servo idea - elimated backlash - zero backlash ! synthetiklone Linear and Rotary Motion 6 12-06-2006 01:35 PM
Moglice Substitute? cbcnc General Metal Working Machines 4 08-01-2003 06:36 PM
Moglice NeoMoses Machine Problems, Solutions , Wireless DNC, serial port 23 06-01-2003 06:00 PM
