Old 02-22-2008, 10:12 AM
deanxd is on a distinguished road
proxxon automatic bit changer
Hey Guys..USOVO is selling a automatic bit changer for the mf70 looks cool but it says it has a runout of 0,02mm. The sort of work I will be doing will be small engravings on the backs of watches and such is this much runout to much on something that small..........Thanks
Old 02-22-2008, 11:33 AM
Stepper Monkey is on a distinguished road
That is just under .0008, which while not great is in practice very acceptable, especially considering the machine in question and what you are using it for. I find for engraving bits you can get away with quite a bit more than conventional wisdom for mills would have it for a number of reasons. Anything over .007-.009 tips with a pretty high included angle or so and you will likely be fine.
That being said, for what you want to do, do you need a toolchanger in the first place? For engraving and that kind of work, setting up and programming in zero and position for each tool and the extra code involved usually takes more time than doing it manually. How many tool changes per path do you need for engraving?
Old 02-22-2008, 12:30 PM
Thanks for your input Stepper Monkey. I think your right it would be to much trouble for what it's worth I didn't think of the extra programming needed.I'm still pretty new at this Thanks again.
I wish I had an Automatic Tool Changer... Chris64 General Metal Working Machines 0 09-09-2007 07:59 PM
Automatic Tool Changer spalm DIY-CNC Router Table Machines 4 07-10-2007 07:49 PM
R8 automatic tool changer N4NV Bridgeport and Hardinge Mills 33 03-05-2007 08:44 PM
Automatic tool changer bunalmis Mechanical Calculations/Engineering Design 3 02-04-2006 03:57 PM
Automatic Pallet Changer DDM CNCzone Club House 4 10-07-2004 10:22 AM
