Old 02-20-2008, 12:44 PM
deanxd is on a distinguished road
proxxon mini enclosure.
Hey... This is my first post on cnc-zone I've learned allot from you guys and I just like to say hi & thanks. I thought I'll show you my currant project an custom enclosure for my soon to be cnc'ed proxxon mf70 it's made from a pvc water main pipe 18'' dia. 22'' tall 5/8 thick and heavy 46lbs. and that's without the epoxy base I'm putting in the bottom. I have included a picture that was my inspiration for this setup. Now it's time to go back down to the basement and start grinding & cutting again pvc dust is the worst everything has a green film on it. I'll keep you posted.......Dean
ID:	53833   Click image for larger version
Name:	Picture or Video 001.jpg‎
ID:	53834   Click image for larger version
Name:	Picture or Video 002.jpg‎
ID:	53835   Click image for larger version
Name:	Picture or Video 003.jpg‎
Name:	Picture or Video 004.jpg‎
ID:	53837   Click image for larger version
Name:	Picture or Video 005.jpg‎
Old 02-20-2008, 01:36 PM
RotarySMP's Avatar
RotarySMP is on a distinguished road
Cool idea Dean
Regards,
Mark
www.wrathall.com
Old 02-22-2008, 03:01 PM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
Thats really awesome man, I like the first pics!
-Jason
Old 02-23-2008, 12:44 AM
Thanks. I'll send more pictures later working on the door right now. WAY WAY to much sanding
Old 02-23-2008, 12:57 AM
laszlozoltan is on a distinguished road
are you planning on machining with flooding coolant ?
Old 02-23-2008, 02:14 AM
I made it up just to try it out works pretty good. I have a full size coolant line but it's just to big for a proxxon. Don't no if I'll need it or not but if I do it's there.
ID:	53984   Click image for larger version
Old 02-23-2008, 08:20 AM
fretsman's Avatar
fretsman is on a distinguished road
Very cool, Dean, the hose setup looks perfect-
Dave->..
Old 02-23-2008, 12:30 PM
Thanks.
Old 02-26-2008, 01:57 AM
proxxon mini enclosure #2
Hey Guys...Well the door is coming along got the lexan in place lots of bondo for the hundreds of holes/scratches/niks/cutmarks. Sent you a picture of my x1 and extremely powerful laboratory grade vac that I plugged solid with pvc dust (DAM 3 STAGE HEPA FILTERS). The only problem is do I put the door on a piano hinge so it swings open or sliders? so it slides around the unit I like to use slides but how do I bend the rails to go around the pipe any ideas to make that work?
Name:	Picture or Video 006.jpg‎
ID:	54200   Click image for larger version
Name:	Picture or Video 009.jpg‎
ID:	54201   Click image for larger version
Name:	Picture or Video 014.jpg‎
ID:	54202   Click image for larger version
Name:	Picture or Video 012.jpg‎
Name:	Picture or Video 017.jpg‎
ID:	54204   Click image for larger version
Name:	Picture or Video 013.jpg‎
Old 02-26-2008, 07:49 AM
Awesome Job! Looks real cool man, I like the whole idea a lot I cannot wait once I have more money too make my enclosure for my Taig Mill! I can't wait!!!
Keep it up.
-Jason
  #11   Ban this user!
Old 02-26-2008, 08:58 AM
Fixittt is on a distinguished road
For the door, I would take into account what type of coolant you will be using. If your going flood coolant the splashing will seep threw anywhere it can. maybe a larger plate under the pipe enclosure. This will catch any type of coolant that gets out of the tube. I really love this idea!
  #12   Ban this user!
Old 02-26-2008, 10:59 AM
Thanks...Jason They also make this pvc in 24'' diameter as well don't no if that's big enough to fit a taig but it's worth looking into. Make sure you get it used from someone in the sewer&water main field cuz buying it new will cost you $80ft.
proxxon mf70 cnc fidia General CNC (Mill and Lathe) Control Software (NC) 0 10-28-2007 11:44 AM
proxxon mf70 hobby fidia General CNC (Mill and Lathe) Control Software (NC) 7 07-03-2007 05:47 PM
Best precizion mini lathe for $1000. Proxxon? samim Mini Lathe 13 02-08-2007 02:33 AM
Can I engrave steel with Proxxon? jaru-eri Benchtop Machines 2 06-28-2006 05:20 PM
Are there any software limitation for Proxxon? jaru-eri Benchtop Machines 0 06-19-2006 07:06 PM
