i see belt drive conversions for the x series of mills and most seem to use v-belts. why is this? i was under the impression that a toothed belt system was more efficient over a v-belt. since the x mills have variable speed motors, i would think the toothed belts would be basically "free" power over a v-belt. please let me know - confused thanks |
| Why do you say that a toothed belt is more efficient than a V belt? Providing your V belt isn't slipping, which it shouldn't be, I doubt there is anything in it. A tooth belt is normally used when you want to maintain "timing" with some other part of the machine. Phil
| Because V belt systems drive on friction the belt needs contact angle in order to transmit power without slipping. This limits the maximum ratio and the minimum pulley diameter for a give power transmission requirement. Tooth belts may be able to transmit more power for a given physical size. Phil |
| I have noticed that with the belt drive conversion from Steele, I do get a little slippage in high speed. I need to quantify that though. This is with a different motor with much higher torque than the OEM X2 motor. The X2 motor would have stalled long before this slip point on this vbelt. It slips some when adjusted correctly because on these two pulleys, the sizes are close to the same size. This doesn't let the vbelt wrap around the pulley far enough to prevent the slip. I am going to turn the smallest pulley off the motor side and lower the motor to be inline with the larger pulley on the spindle. Hopefully this will give me more torque. I know it should give me more speed. If this doesn't do what I want, I will use a timing belt. They surely won't slip. I have a serpintine belt on my truck. It is a multi groove belt. I think it is a lot more forgiving of pulley size and can carry more torque than a standard vbelt. They have much more surface contact to spread the friction on. A timing belt is more like a chain and sprocket. It doesn't use friction, but teeth instead.
__________________ Lee |
| I an no engineer, so I can't quote any formulas for efficiency between the belt types, but a toothed belt that needs less pressure on the belt to work and has no chance of slipping, seems to me to be more efficient than a vbelt.
| Yet but a slipping V belt is a gentle reminder to ease up a bit. With a toothed belt it just eats itself if you over load it, V belts are much more forgiving when abused. More or less efficient depends as much on your ability to design th system correctly as it does on the system you use. Phil PS: A good engineer is somebody who can do for a penny what any fool can do for a pound (GB pound that is).
| i am just basing my question off of the years i use to work at a machine/performance shop. take superchargers - the smaller ones likes paxtons (not sure what else is a smaller supercharger, been out of it for a long time) and the like would use serpentine belts at most, but the larger 6-14/71s would use a form of a toothed belt due to the amount of power they need and also their efficiency. i just downscaled the items but thought the same principles would apply - less wear and tear on the rotating parts and more power going to the cutter due to less friction in the transmission of the power |
| It is true that V belts use friction to transmit power but providing there is no slippage there is no frictional losses. The use of a tooth belt on a supercharger may be more to do with the compactness of the design rather than any efficiency considerations. V belts drive systems are used the world over in machine tools with much higher power requirements than a small bench top mill. Phil
#10
| to be honest i can't remember the numbers but even when people would put a toothed belt setup, at least on cars, for smaller items like alternator, a/c and steering there was less of a hp rob than the vbelts. if i remember correct, the order of efficiency went toothed, serpentine and then vbelt. i will look for #s to back up what i am saying. and these were dyno proven, but i guess in the scheme of things, the amount wasn't high in the %s as these were high hp street engines - 500-700HP on average. i just figured that since we were dealing w/ much smaller units of power any additional benefits would be exponentially better. |
#11
| Most of the higher HP v belt setups use multiple belts as well. Matched belts too. These are costly, but very effective at spreading the friction needed to drive a load. Even matched v belt sets for big machinery are probably a lot cheaper than the same size in a timing belt or multi v belt. It still all comes down to design, cost and effectiveness or put altogether, efficiency. The L belts in the Steele belt conversion are really small, but they are fully suitable for the duty it was designed for on an X2 head. I increased the available torque with another motor and then the design starts to show it's weakness. If the belts were designed correctly with the right sized pulleys for this larger motor, I should be able to stall the motor before the belt slips. That is the case with the original motor and design. To get the torque I have available, I will have to modify or redesign. Since there is very limited space atop the X2 head, a timing belt would likely give me the best performance and the least amount of slippage. Here is an image of my motor setup with the Steele belt drive. You can see there isn't much space to work with there.
| Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? | pfeist | General Metal Working Machines | 11 | 02-13-2012 02:12 AM |
| X3 Belt Drive? | pzzamakr1980 | Benchtop Machines | 16 | 11-14-2007 10:15 PM |
| Belt Drive help | bearwen | Linear and Rotary Motion | 5 | 10-31-2007 03:55 PM |
| X1 Belt Drive? | Tag1260 | Benchtop Machines | 12 | 08-31-2007 05:38 PM |
| Belts versus Direct Drive | bsmith | DIY-CNC Router Table Machines | 12 | 06-06-2004 10:09 PM |
