Old 02-15-2008, 07:29 PM
Oldboy is on a distinguished road
Is anyone using all metal gears in there X2?
I know alot of people use the Belt drive.
I was just wondering if ANYONE is using ALL METAL gears in the spindle head on a X2 MILL? Tell me about it?
Old 02-16-2008, 07:49 AM
krymis is on a distinguished road
i am actually using the metal gear set from the hobbyist machine store. They are noisy, but they can take a beating without slipping. After i make the rest of my cnc parts I will be making a belt drive to replace them. If I had to do it again I would use the gears simply because I now have knowledge of them and it will help to build the machine i want.
Old 02-16-2008, 11:12 AM
cjdavis618 is on a distinguished road
I use the Belt and can't see a reason to use the gears. The added noise would be to much for me.
As far as the belt slipping, that has never occurred on my mill. I have had the motor stall but that was the controller and not the belt. If the belt kit is installed properly you will not have problems.
Old 02-16-2008, 03:22 PM
Krymis.
So If you had to do it again you would NOT use the metal gears?
Im not sure I understand your view point? Please explain?
Build cnc router without linear ball bearings ?? Flat metal on flat metal with lube ? vroemm Linear and Rotary Motion 7 08-16-2007 12:26 PM
Gears georgecort General Metalwork Discussion 2 04-27-2007 11:58 AM
gears georgecort GibbsCAM 0 04-21-2007 06:11 AM
who's going to GEARS CerveloRod CNCzone Club House 6 09-20-2005 07:11 PM
