OK....my next major project is almost done. I got my flood coolant enclosure almost done and all the piping hooked up. Everything seems to run A-OK. I see in Mach 3 that I can run the coolant from the program. HOW? What do I need to get this hooked up? I searched the site and I saw mention of a relay, but that was about it. A nice little easy to read drawing would be cool. I am electrically challenged btw. ![]() Mike |
I might be able to draw you a picture but I'd need to know what kind of breakout board you're using. Personally I'd recommend the LocoCNC controller, since I helped design it, and I know the documentation covers the relay part But most of them will work fine for your application. |
| http://www.cnc4pc.com/Store/osc/prod...products_id=45 Luckily they sell a relay board for it here: http://www.cnc4pc.com/Store/osc/prod...roducts_id=148 (this one will work as long as your coolant is less than 10 amps at 125VAC) Buy it. Then hook it up like the instructions, wire the AC source in like you would a household light switch (i.e. the 'hot' leg gets switched). Here's the documentation: http://cnc4pc.com/Tech_Docs/C8-AC_RELAY_Manual_Rev2.pdf Also very important. If you have the $22.50 to spare, buy the charge pump: http://www.cnc4pc.com/Store/osc/prod...products_id=51 This will save your machinery in the event of a Windows/Mach3 lockup or crash. This should have been standard equipment on the breakout board, but that's what you get on a cheaper board. Hope this helps.. Good luck |
LOL. For me and building electrical stuff....it is all rocket science. I'm personally surprised the electrical stuff hasn't given me problems while building my mill. Mike |
#10
I'm sort of wondering if it is even worth putting the coolant control into Mach3. I have a power strip with the coolant pump plugged into it and I just reach over and turn it on when I want the pump on. Turn it off when I don't need any more coolant. But, OTOH, I want to take advantage of the full capacity of Mach3 and my setup and adding the coolant controls in would just be a step in the right direction. I eventually want to add a spindle control and a computer controlled rotary table. Between the cnc4pc site and the cartertools site, is there any advantages one over the other? Mike |
#11
#12
Mike |
| Flood coolant option | truline | Haas Mills | 14 | 05-18-2011 06:00 PM |
| Coolant, Flood, Mist, WD-40, etc | Smitty911 | Benchtop Machines | 37 | 11-15-2009 09:15 AM |
| My SX3 flood coolant base | metalworkz | Syil Products | 5 | 09-16-2007 04:24 PM |
| Flood coolant on steroids | Scott_bob | Machine Problems, Solutions , Wireless DNC, serial port | 7 | 04-30-2007 01:07 PM |
| question about flood coolant | nicad | General Metalwork Discussion | 6 | 10-24-2005 10:03 PM |
