Old 02-06-2008, 07:16 PM
lagfish is on a distinguished road
nook ballnuts
For those of you who have converted to CNC using the nook ballnuts from homeshopcnc, can someone sell me their 15/16" (0.9375) 16TPI tap for screwing in the ballnuts? I don't have much experience with internal thread cutting on a lathe so I don't want to waste time on it. Thanks
Old 02-06-2008, 07:25 PM
Runner4404spd is on a distinguished road
wholesale tool carries it, if you want to buy it new. they aren't that expensive. i don't want to give mine up but i'll tap your parts for you if you want to send me the peices.
Old 02-06-2008, 08:22 PM
ger21's Avatar
Ebay
http://tinyurl.com/2nf2kd
http://tinyurl.com/2jfplp
Old 02-06-2008, 09:11 PM
ataxy's Avatar
ataxy is on a distinguished road
the new nut they carry at homeshopcnc a pretty expensive compared to the one they had before i was checking with them the other day to get two one for the x and one for the y here is the price i got from them
Screw stock: $1.89/in
Ballnut: $95/ea
Fixed end support: $120/ea
Free end support: $55/ea
Standard end machining for fixed end: $85
End machining for free end: $25
so if you want double ballnut your allready at 400$ just for the nut
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
Old 02-06-2008, 10:34 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
Check e-bay. I got mine for about 20 bucks delivered. Take the delivery time to figure out how to tap that big hole square in all directions and on center.
Paul
Old 02-06-2008, 10:39 PM
acondit's Avatar
acondit is on a distinguished road
Ballnut: $95/ea
Ataxy,
The specs on the new line looks like metric 1605. Do you know if that is correct?
Also he has the accuracy as 0.0018"/inch, that would be 0.021"/foot? Is that right or is it supposed to be 0.0018"/foot?
Alan
http://www.alansmachineworks.com
Old 02-07-2008, 01:14 PM
ataxy's Avatar
Originally Posted by acondit View Post
Ataxy,
Alan
yep there metric humm it must be 0.0018 or else accuracy would be pretty bad
Old 02-11-2008, 06:07 PM
hmm, didn't realize how cheap it is. I will just buy it. Thanks for the offer though, Runner4404spd.
Old 02-11-2008, 06:22 PM
DonF's Avatar
DonF is on a distinguished road
Paul
I'm no expert on a lathe but another site had a new person with a lathe recommending cutting 1/2 depth threads on the lathe. Then finishing with a tap... That method gave him good results or so the post said.
I know most experienced lathe people cut threads with no tap to chase the threads. I figure I will practice on scrap until I get the results I want.
Old 02-11-2008, 08:59 PM
I was just going to hold the tap on the tailstock, but I now that I think about it, the tailstock is probably not dead on center. Half tapping the threads on the lathe sounds like a good idea, since the hardest and most time consuming part is finishing the threads because you have to go a few thou at a time for the last bit and try to fit your part in after each pass.
On the Y-axis of the x3, a small missallignment isn't a big deal since the ballscrew is supported only at one end. But a missalignment in the X or Z might cause the ballnut to seize near the ends of its travel when the room for deflection of the ballscrew is small and also cause premature wear on the balls.
  #11   Ban this user!
Old 02-12-2008, 08:46 AM
Neil_J's Avatar
Neil_J is on a distinguished road
I have three flange nuts for the Nook ballnuts that I won't be needing. I'll sell them for $6 each (+shipping&paypal fee). PM me if you're interested.
  #12   Ban this user!
Old 02-12-2008, 08:52 AM
ataxy's Avatar
are the thread 15/16
Joining 2 Nook Ballnuts - any ideas? Rodm1954 Linear and Rotary Motion 9 06-15-2006 07:16 PM
keystone vs nook tomcook Linear and Rotary Motion 0 03-14-2006 11:04 PM
Screw, Bearing, Motor assembly (Nook) Ziggster Linear and Rotary Motion 5 03-14-2006 08:28 PM
Ballnuts: Do you really need all the balls? geohot Linear and Rotary Motion 3 12-27-2005 12:34 AM
Anyone know how much nook ballscrews are? sendkeys General Metal Working Machines 10 07-02-2004 12:48 AM
