Old 02-06-2008, 06:43 PM
Oldboy is on a distinguished road
Anyone using TurboCAD/CAM PRO 12 to run X2?
Im looking now for software to run my X2 mini mill.
Need it to do 4 Axis control on mill. 4th axis to do gears,Threads inside & outside,Tapers and rounds ect.
So i was wondering if TurboCAD/CAM PRO 12 will run the steppers on a X2 mini mill? Or do i need Mach 3? And a CAD software.
What are you all using?
Old 02-06-2008, 08:19 PM
DonF's Avatar
DonF is on a distinguished road
Tubocad12 is outdated and buggy - 14 is the current version
Turbocad Pro 14 is the CAD Program
The Turbocad CAM plugin generates the G code, it will not work without the CAD program
Yes you will still need a controller like Mach....
Old 02-07-2008, 05:08 AM
philbur is on a distinguished road
TurboCadCam provides 3D CAD but only 2.5D CAM. You will still need control software like Mach3.
Cad does the drawing
Cam converts the drawing to gcode
Controller software use the gcode to generate signals to the stepper/servo motors.
True 4 axis Cam software is expensive.
I use TurboCadCam v11.3 and Mach2
Phil
Turbocad/cam marvinstov TurboCAD/CAM 23 09-24-2007 03:34 PM
TurboCad Pro 12 Gandalf TurboCAD/CAM 5 12-22-2006 10:39 AM
TurboCad Help.... IN-WondeR TurboCAD/CAM 0 06-22-2006 12:07 PM
I suck at TurboCAD Darren General CAM Discussion 26 09-06-2005 01:12 PM
Turbocad DXF help qsacracer TurboCAD/CAM 1 12-18-2004 02:22 AM
