Hi guys - I need to make a custom pulley to go onto the X3's spindle. Looking at the thing, it seems to be a 20mm shaft with 6x 5mm wide, 2.5mm deep splines sticking out. I had a go at making one by drilling some 5mm holes on a 20mm pitch circle, and then boring the centre out, but it just doesn't fit, and I've mangled it trying to open it up by eye. I don't suppose anyone has a CAD drawing or a smart way to make one? Cheers. |
| if you have the origonal pulley use the centere and fit it to a new exterior if you see what i mean alternativley measure it and draw it out in cad make a broach from silver steel then cut your own pulley if its an ali one will work just fine make the broach about 0.002" small and pre-machine as much away as you can mike |
| Thanks Mike unfortunately I don't have an X-3 or even an original pulley to measure! Looking at the exploded diagrams on ARC Eurotrade, the X-3 seems to use some conventional gear with a large bore and a single key-way, which then fits over a sleeve with internal splines which engages the splines on the spindle. I guess I am going to have to try entering the profile into my CAD tool, and then using sheetcam to rough out the splines with an endmill before using a hand file to square them off. I am also considering just boring out my pulley to just fit over the outside of the splines, and then to use 3 or more set-screws to engage the splines and keep the pulley centered. I'm not sure which is a better approach, but as I already have a half scrapped pulley which could be bored, I might give that a go first. Cheers. |
| First off, are you trying to increase spindle speed. If so you can do this without screwing with the spindle pulley by simply switching the motor pulley and the other pulley. This gives a theoretical spindle speed of 6600. I figure a realistic speed of 5500 is a sure thing. Secondly, if you are trying to get rid of the gears for noise, go to econobelt or spdi, both of which have adds on this site, and purchase two pulleys for htd5 pitch belts. Get one 30 tooth and one 32 tooth. Try to purchase the narrow, 6mm or 9mm belt, whatever size they mention on the arceurotrade site. Then simply cut off the gears on each stock pulley and bore out the two aluminum pulleys you got and do a nice tight fit and toss some epoxy on there and never worry about it again. If you are scared of ruining your pulleys buy some more from grizzly, they are really cheap. This will cut the noise level nearly in half. |
Cheers. |
| Mutt Machine Motor & Spindle Pulley Combo | mikkojay | Benchtop Machines | 0 | 01-22-2008 01:37 PM |
| How do you deal with the noise from the spindle pulley? | david_geng | Syil Products | 0 | 07-08-2007 06:03 AM |
| Wear in spindle splines or pulley | cut more | Bridgeport and Hardinge Mills | 11 | 07-03-2007 06:31 AM |
| help..Any Asian Made Spindle ? where to buy it ? | Calico | General Metal Working Machines | 2 | 08-31-2006 01:22 AM |
| Removing pulley from Taig spindle | warpedmephisto | Taig Mills & Lathes | 13 | 04-02-2006 04:53 PM |
