Old 02-03-2008, 03:01 PM
bryanrabb's Avatar
bryanrabb is on a distinguished road
Which is harder to make?
On cnc mill? Gears or sprockets? And what is the best way to cut each one? I have no clue, so any help would be appreciated.
When all is said and done, more is said than done.
Old 02-04-2008, 10:14 AM
Anokiernan is on a distinguished road
I've never machined either a gear or a sprocket on my taig, but i'd imagine that making a sprocket would be the simplest. To the best of my understanding a gear would require a specialized gear cutter and rotary table or indexing head, where a sprocket could be machined simply with an endmill and a single flat setup on the x-y table, no need for an A-axis.
Old 02-04-2008, 11:09 AM
neilw20's Avatar
neilw20 is on a distinguished road
Cool Sprocket info.
Machinery's Handbook has the geometry for sprockets.
Fairly easy to create the correct shape in a cad package.
If you like hitting your head you can generate with Lisp.
In Google serarch for 'sprocket lisp'. Plenty of ready made programs/plugins are on the net.
Super X3. 3600rpm. Two possible way to fix things: The right way or the other way.
Old 02-15-2008, 11:18 PM
sansbury is on a distinguished road
Using CNC it *might* be feasible to cut the part as a 2D profile, but it may require a very small end mill (1/16" or less( depending on the gear size. The easy and best way for either a gear or a sprocket would be to use a rotary table.
A sprocket can probably be cut with an end mill or woodruff-type cutter pretty easily if precision is not required, but something like a bicycle sprocket is just as complcated as a gear. Gears require a precise tooth shape or profile to mesh correctly. The most common type are called "involute" gears and there are several ways to make them.
One is to buy a set of involute cutters which look like circular saw blades with a precise cross-section. It takes a set of 8 cutters typically to be able to make a full range of gear tooth counts and they cost $10-$25 per cutter. The other way is to use a hobbing cutter AKA "gear hob."
One hob can make a gear with any number of teeth in a given pitch size. Commercial hobs seem harder to come by than involute cutters but you can make a hob yourself pretty easily with a lathe and mill--it's basically something like a plug tap. Smartflix has a video called "Making Gears the Easy Way" which takes you through all of these different processes including the math.
Gears these days are also made using wire EDM but that is a whole 'nother ballgame
Best Way To Make This? DroopyPawn General Metalwork Discussion 8 12-16-2007 12:34 AM
What do you make and How do you make it??? cyclotron CNCzone Club House 0 11-27-2007 10:55 AM
What can I make With this? Siren Joes CNC Model 2006 1 08-16-2007 06:23 AM
trying to make a die. Dougotio Diemaking and Diecutting 9 04-08-2006 06:37 PM
How can I make cncman General Electronics Discussion 3 03-23-2004 02:49 PM
