Old 01-31-2008, 07:31 PM
Oldboy is on a distinguished road
Delrin Nuts for a X2 CNC MILL?
I know nothing about Delrin Nuts.
Are they strong? Will they wear out fast on a CNC?
Why use them? Back lash?
Old 02-01-2008, 09:16 PM
ANYONE GOT INFO OR USE THIS TYPE ON THERE MINI MILL?
Old 02-01-2008, 10:25 PM
LeeWay's Avatar
LeeWay is on a distinguished road
I don't have any delrin nuts, but I did thread some to capture my ball nuts in and lock them to the steel flange.
Delrin is some really nice material. It is hard and does not wear very fast. It has it's own lubrication somehow. Just fairly slick stuff. It machines well also.
Take a look here.
http://www.dumpstercnc.com/leadnuts.html
Contact them and they should be able to give you all the specifics you might want to know about wear.
Many of the guys here have used these Dumpster nuts.
Lee
Old 02-01-2008, 10:47 PM
Thanks for the info LeeWay.
Old 02-02-2008, 12:17 PM
blades is on a distinguished road
Yes, delrin has phenominal wear characteristics. It's not as strong as bronze, but should be strong enough for a small mill application. My only concern is if you're using delrin as an exact replacement on an X2 mill for the existing nut, the delrin may flex a bit.
how tough are delrin nuts dertsap Open Source CNC Machine Designs 9 09-18-2007 11:51 PM
Making 200+ Delrin Flange Nuts - Messy! widgitmaster Bridgeport and Hardinge Mills 8 09-08-2007 03:21 PM
ACME Leadscrew Acetal/Delrin and Ballscrew Kits and Plans for the Sieg X2 Mini-Mill fignoggle Product Announcements & Manufacturer News 0 04-21-2006 09:36 PM
How would i mill copper/delrin with miniature tooling? Please help a novice. touser General Metalwork Discussion 5 01-05-2006 08:20 PM
Delrin nuts for lathe? kong General Metal Working Machines 5 04-23-2004 08:26 AM
