#98
| Here are the springs installed. The upper mounting sleeves are pieces of black plastic that hold the big ends of the spring on the outside diameter. The small ends are supported with sections of aluminum tube the fit the inside diameter of the spring. Neither end holds the spring tightly, the spring can move freely at both ends. I must say that this way of protecting the ball screw has completely exceeded my expectations; it just works great. The ball screw and nut will stay perfectly clean. Bill |
#99
| Your mill is shaping up nicely. I agree, thaose ball screw covers are going to make sure the screws are nice and clean. Very nice instalation too.
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
#101
#102
| bilinghm, Excellent conversion and writeup! What are your X, Y and Z travels after all of these modifications? Were you able to use the ballscrews that came with the standard CNC fusion kit? Where did you get your limit switches? Thanks |
#103
| Sorry for the slow reply, The X and Z are unchanged, the Y is increased to 4.5", a valuable gain. The limit switches are from Surplus Center. |
#104
| If you can't get them surplus, here's a switch that should fit nicely: http://search.digikey.com/scripts/Dk...keywords=ch606
__________________ ~Don |
#106
Great read, and lots of ideas for me to implement. Thanks, Steph |
#107
| What an excellent job. I just read thru the whole thread and really appreciate your efforts to document the build. Your bellow covers look very good, maybe a little more info on exactly how you glued those so uniformly. Did they hold up under real world conditions? and 1 last question, these cant be your hands holding the bellow covers are they? Clean smooth skin and shiny nails?
| Took the BIG PLUNGE | HelicopterJohn | Haas Mills | 75 | 01-11-2008 10:39 PM |
| Plunge Milling | binzer | GibbsCAM | 7 | 05-29-2007 02:31 PM |
| Plunge roughing? | RdHawg | Hypermill | 3 | 01-03-2007 05:42 PM |
