  #13   Ban this user!
Old 02-04-2008, 11:33 PM
delwood is on a distinguished road
Originally Posted by Glennza View Post
One of the nice things about TurboCNC is that it runs on DOS, which means an old, slow, obsolete computer will run it nicely. By asking around, you could probably come up with several computers that would work. Then you would have a dedicated machine controller and not have to share when you want to use it as "your" computer. A Pentium 200MHz to 500MHz with 8 Megs of memory will work well. I'm setting mine up with a CompactFlash card as a hard drive, so there are no mechanical parts to fail in a dirty shop environment. Someone you know would love to give you that old computer that's taking up room in the back of the closet.
Glenn
Glenn,
I like that idea. Just find another old, slow, obsolete computer besides the one I'm using for "my" computer! Is that 8 meg required for the flash memory? The computer isn't the only item here that's old and slow but I refuse to become obsolete.
Thanks, Delwood
  #14   Ban this user!
Old 02-04-2008, 11:41 PM
Originally Posted by BrassBuilder View Post
As a newbie CNC machinist myself, I can vouch that building the machine was the easy part! I am at the figuring out the software stage right now. Here is what has been the easiest combination (for me) as far as the software goes:
CAD: TurboCad Deluxe (I think I am running version 11.something.)
CAM: CamBam
Milling Software: Mach3
I am still learning this as I go....I am now in the firm belief that there is nothing "easy" about the software part. One package might be less confusing than the other, but they all have a certain learning curve that will take time to figure out. Is CamBam the "best" CAM software? Probably not. But I am finding it has been easier to learn than any of the others. You can also ask 10 people on the board what combination they are running and you will get 10 different answers. Good luck!
Mike
Mike,
My daughter handed me TurboCAD version 9.1 she decided not to use. Do I use it or do I need the 11.something?
Thanks, Delwood
  #15   Ban this user!
Old 02-05-2008, 04:24 AM
Glennza is on a distinguished road
"Is that 8 meg required for the flash memory?"
Yes, 8 Megs is plenty of RAM to run DOS and TurboCNC. After all, in the "good old days" we used to run on 512k of memory and thought it couldn't get any better than that. Actually, you'll probably have to run more memory because those small sticks of RAM aren't that easy to find any more.
Glenn
  #16   Ban this user!
Old 02-05-2008, 05:39 AM
BrassBuilder is on a distinguished road
Originally Posted by delwood View Post
Mike,
Thanks, Delwood
Give 9.1 a try. But take a look and see if the program will save your drawings in a DXF format. You will need that format for CamBam.
Mike
Step by step cnc plasma with parts list and links. massajamesb CNC Plasma and Waterjet Machines 8 07-08-2007 10:22 PM
Step by step turret realignment adamant Linear and Rotary Motion 1 03-12-2007 05:49 PM
TORQUE: FULL STEP vs half step Glidergider Stepper Motors and Drives 0 02-27-2007 02:02 PM
step by step instruction for building controller avengine CNCzone Club House 0 04-21-2006 07:24 AM
Single Step/Half Step Question Hawkeye DIY-CNC Router Table Machines 4 11-20-2003 10:28 AM
