yes you can as long as the assembly and adjustment of your conversion are well done also the way the machine is used will affect its precision so as long as you respect the capacity of your small machine you will be able to get result as good as there huge sister the result realy depends on the way the machine is worked on and the quality of the component and tool use on it
LinkBack URL
About LinkBacks
