Old 01-27-2008, 01:00 AM
ataxy's Avatar
ataxy is on a distinguished road
table tilting problem
ok i have a slight problem, two days ago i got a longer table for my "bf-20" mill and i have a slight problem with the adjustment i have some tilting i would say about 0.003" to 0.004" on a distance of 6" i did play with the gibs but even with them tighten all the way i get those reading, i can easly see oil been pushed out when i push up and down on the table in between the table and the y saddle the only way i can minimize it more is by tightning the two lock screw in the front but this is not an option since it locks down the table any idea would be appreciated
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
Old 01-27-2008, 02:44 AM
ataxy's Avatar
ok never mind i found the problem the gibs and the dovetail of the new table do not match... well not that it does not match but the with of the dovetail of the new table is slightly smaller so ounce the screw was screwed all the way the gibs still had some play so well i found a temporary fix by adding some masking tape to the back of the gibs wich made it a bit thicker by 0.005 but it could still be a bit thicker cuz i still get about 0.0015 of play when i push up and down so ill try to see if i can find a 8"x0.5"x0.006 strip of shim since a shim wont also have the squishiness of the masking tape
My cnc table scrambled Plasma, EDM and other similar machine Project Log 104 07-24-2010 09:11 AM
machine problem or software problem? bcnc Syil Products 8 10-26-2009 10:51 AM
Left tilting or Right Tilting Table Saw Blade? diarmaid Wood Working Tooling 16 02-27-2009 09:57 AM
XY table design basics, linear ways to table size ratio? Konstantin Mechanical Calculations/Engineering Design 0 03-13-2007 01:21 PM
Heidenhain TNC 426 - rotary table problem nbjs General CNC (Mill and Lathe) Control Software (NC) 8 12-05-2006 10:52 AM
