#49
Obviously if you have the extra cash, the Rex system is the winner here. Only $150 more, but better accuracy and more X/Z travel (compared to double-nuts). Hmmm C7 quality versus T8??? I'll find somewhere else on my machine to save $150. Yep I know where my money's going |
#50
#51
| Neil,I agree the homeshop Rex is the best accuracy for the money,but you must determine that the ballnut is not to large.Next choice would be McMaster carr.At Reid thompson nuts are$124.00??THK's at MSC are to reduculous to bother. Here is some Roton info I got from searching the CNC Zone. Lead accuracy anywhere from .003 to .010.Apparently you can request .003.Rolled screws can vary a lot and manufactures select and grade what they rolled. Many Zoners used Roton and are quite happy.Perhaps they got lucky.A call to Roton may be in order to confirm the .003 request.If they can supply they would be the best bang for the buck.Sorry I know nothing about mills.I researched screws for a 5X10 wood router and have to go R&P.Even 10'Rotons are $700. Larry
__________________ L GALILEO THE EPOXY SURFACE PLATE IS FLAT |
#52
#53
| Dredging up an old thread but my clearance model for the X3 indicated that without milling/grinding the nut flange on the new Homeshop nuts they would not fit. The reason you got a sticker shock with a quoted price on the Nook nuts is because the nuts that should go with the XPR screws are not what Homeshop (and CNCFusion) were/are offering at ~$30 a piece. The nuts they were offering are the cut nuts not ground nuts which are intended to be paired with the SRT screws. I opted to drop to the cut nuts and save the $$. I threaded one on when my 6' of screw and 3 nuts showed up (2 for X and 1 for Y which will get preloaded with some oversized balls) and the fit was beautiful. Rolled all the way down to where I rolled the sheath back on the screw with no effort whatsoever, shaft was barely elevated from horizontal, and there was no perceptible lash, but under load I'm sure that'll change. Once I get my X and Y machined, turned and installed I'll design the Z around the same screw (got a 6' standard length which is enough for all 3) and should be up and running by the end of March. |
| Ballscrew conversion | rodzilla | Benchtop Machines | 7 | 01-23-2008 07:40 AM |
| Enco 8x36 ballscrew conversion | James Willis | General Metal Working Machines | 1 | 08-25-2006 10:35 PM |
| Ballscrew mounting | m_c | Linear and Rotary Motion | 1 | 03-11-2006 03:51 PM |
| CNC Conversion - Ballscrew Questions | Deviant | Benchtop Machines | 15 | 03-28-2005 09:35 PM |
| Mini-Mill Ballscrew conversion? | rustyolddo | Benchtop Machines | 2 | 07-29-2004 10:22 AM |
