Very nice conversion! Congratulations.
I will be interested to see how well the lead screws and nut hold up with a small amount of backlash.
What are you using for way and lead screw lube?
How often do you lube it?
Good luck.
Pres
You can see my conversion of the Sieg X1 here
http://www.affabel.se/hobby/cnc.htm
Good luck.
Pres
I have just put a few drop of oil on to the screw and bearings.
I have only run the cnc for about 10 hours so far
Since the cnc conversion I have only lubed it once with ordinary oil. It's only been used about 10 hours.
how much did you pay for the touch screen
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
I live in Sweden and I paid 1699 Sek that is about 200$
