Old 01-18-2008, 05:23 PM
SPEEDRE is on a distinguished road
Question Solutions for Lifting head
The usual implement for lifting the milling head is that torsion spring arm arrangement, but that's not good enough for me. I want the same action as on a drill press. You know with the right stuff to lift it to where you started. What about two 50lb lift gas tubes mounted to the side of the mill head? Help, I really hate the present system.
Old 01-18-2008, 05:53 PM
chich2 is on a distinguished road
What about roller chain and weights? Or a pneumatic cylinder with a vented regulator. CNC machines have either of these and they work perfectly.
Chich
Old 01-18-2008, 06:29 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Any pictures, they would help answer your question!
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 01-18-2008, 10:01 PM
LeeWay's Avatar
LeeWay is on a distinguished road
I have a gas spring on mine. It is a 30 pound model. Works nicely.
Lee
Old 01-19-2008, 11:11 AM
LeeWay's is what I'm after, needed to see if someone else used it. Sorry not good with camera not digital yet.
z axes lifting John Teichman Mach Mill 6 02-10-2008 10:12 PM
Sheet stock lifting. fer_mayrl WoodWorking 2 05-01-2007 01:38 PM
Lifting fixtures on and off the machine. Smackre General Metal Working Machines 5 04-02-2007 01:18 PM
Heavy vice lifting Pat2000 Safety Zone 26 03-16-2007 01:10 PM
DIY Lifting Cart using 4 bottle jacks! damae General Metal Working Machines 23 06-07-2006 06:51 PM
