  #13   Ban this user!
Old 01-22-2008, 06:47 PM
BrassBuilder is on a distinguished road
Originally Posted by mikkojay View Post
The pcb has a single wire soldered to it, the end of which is attached to a parallel input pin. This pin is designated in the ports/pins config as the probe pin.
-Mike
This would actually go on the breakout board on one of the input ports, right? If so, that sounds simple enough to make. I think I can figure out the VB stuff. I used to write a little for Microsoft Access databases.
Mike
Old 01-22-2008, 06:54 PM
mikkojay's Avatar
Gold Member
mikkojay is on a distinguished road
Yep, you got it. The tool in the holder is grounded to the machine's electrical ground level 0vdc. The input pin/plate are hi, so when the tool touches the plate, mach3 sees the pin go lo 0vdc. It then knows to kick the vbscript out of the loop it is in and go on to the next step. Having a little script experience will definitely come in handy.
-Mike
Expensive tools can be cheaper than professional therapy
  #15   Ban this user!
Old 04-13-2008, 05:56 PM
seanreit is on a distinguished road
-Mike
Where are the instructions to make this device and hook it up to the Taig Controller box? I have searched all day for it and this thread was the closest I could find to describing it.
Thanks so much.
Getting the X and Y of my First CAM location vpcnc BobCad-Cam 4 06-22-2007 09:34 AM
What is the X & Y Location Joe Crumley Commercial CNC Wood Routers 3 04-09-2007 12:42 AM
Map your location Rekd CNCzone Club House 20 10-20-2005 09:49 PM
location mocnc DIY-CNC Router Table Machines 15 04-08-2005 04:12 PM
location? fastolds Surfcam 11 12-02-2004 01:58 AM
