Old 01-16-2008, 05:07 PM
lvittori is on a distinguished road
Will this work as a facemill?
Can this be used as a facemill on the X2?
http://cgi.ebay.com/3-5-FLUTE-R8-IND...QQcmdZViewItem
Old 01-16-2008, 05:55 PM
LeeWay's Avatar
LeeWay is on a distinguished road
I'd say that one is a bit too large for a plain X2. I bought one like it @ 1.25". It works fine. I think the max recomended is 1.5". I do use a 1.5" flycutter sometimes.
Lee
Old 01-16-2008, 05:59 PM
Thazul is on a distinguished road
In my X2, I use the 1-3/4" version of this - http://cgi.ebay.com/2-INDEXABLE-R8-E...QQcmdZViewItem and I love it.
I know I've heard others talk about this one from Grizzly - http://www.grizzly.com/products/Fly-Cutter/G2861
Have a look at Hoss's thread, He's using a fairly large face mill. - X2 cnc finished for now maybe
Best Regards
Andy
Old 01-16-2008, 06:19 PM
Thanks for the replies. I saw a thread where Hoss said he was using a 3" 5 insert facemill to take .010 off a tool plate he was making and he said plenty of power. I'm still fairly new to this so I wasn't quite sure if that mill would work since the ad says endmill. I've been trying to use a 1/2" endmill and the surface finish leaves a lot to be desired. The pictures of the tooling plate Hoss was working on looked like it had a great finish but there again he's a professional and I'm an amateur.
How much of a difference would you see in the finish between the 3 insert 2" mill and the 5 insert 3" mill?
Lucian
Old 01-16-2008, 08:44 PM
toastydeath is on a distinguished road
The finish on the 3 flute should actually be a bit better, unless you're using a wiper insert in the 5 flute. The trick is to calculate the feed instead of guessing.
The major consideration for power in a facemill is how many teeth it has, not the width. You should be able to run a 5" wide three flute facemill in aluminum on most machines successfully, it just won't be the fastest thing ever.
For large widths in one pass on a low power machine, or for excellent surface finish, the best suggestion is to use a flycutter and crank the depth in to reach the machine's capacity.
Old 01-16-2008, 09:55 PM
GoFaster is on a distinguished road
Originally Posted by toastydeath View Post
...crank the depth in to reach the machine's capacity.
Does this mean keep increasing the depth of cut per pass until the machine complains? Could you please elaborate?
Old 01-16-2008, 10:41 PM
Yes, that's exactly what I mean. It will get louder and louder with a deeper cut, but the sound stays the same until you reach the machine's limit.
You can hack off a ton of aluminum with a flycutter, I've had .300"-.400" depth of cut on a Bridgeport with a 4.5" flycutter, about .007"-.010" per rev. This particular cutter had a negative radial rake, so the tool was sturdier than most.
Old 01-17-2008, 06:41 AM
Thanks for all the input. I ordered one of the 2" 3 insert mills last night and hopefully I'll figure out how to use it well enought to get better results than using my 1/2" endmill.
Old 01-17-2008, 12:46 PM
impact is on a distinguished road
Fly cutters do amazing work when your machine is set up properly.
I dont know why you would really use anything else for strictly facing, minimum material removal.
Old 01-17-2008, 03:48 PM
Well...I have the endmill on order but after reading your input on fly cutters I looked at the grizzly web site and they have a set of 3 for a reasonable price. I may have to order those next payday to do a comparision. One can never have too many tools.
  #11   Ban this user!
Old 01-17-2008, 08:25 PM
blades is on a distinguished road
True dat. I used to use fly cutters all the time when I ran a Bridgport. One real advantage I can see with these insert cutters is that you get 3 fresh tips per insert, with no tool grinding. With a fly cutter, the home machinist would need to have a bench grinder with a green wheel to regrind the carbide tool bits used with a fly cutter, although high-speed would work fine for aluminum. Not to mention they'd have to have experience with tool grinding to know how to grind the tool bits.
With a carbide insert cutter such as those, you can cheat 7 ways to Sunday if you know what you're doing with them. For example if you do have a green-wheel, you can regrind the carbide inserts (as long as the cutting edge remains set off from the cutter body). You can also cut with 1 insert if you remove the other clamps, and adjust your feed, speed, and cut depth accordingly. Some of the most agressive insert cutters I've used on a Bridgeport were small diameter, single-insert cutters.
  #12   Ban this user!
Old 01-18-2008, 02:01 AM
I purchased a cheap 3 piece set of fly cutters and some square tools for them prior to finding the face mill on ebay.
I have no experience with grinding the tools, after some reading I got it to work alright, but...
Those cheap fly cutters are made of a really soft metal, and I've had the square tools that go in them actually wiggle loose, damaging the holder.
I had the set screws really tight too...
That indexable face mill you purchased will cut like a dream..
Mine leaves a beautiful finish on aluminum. (never cut anything else with it)
Andy
Facemill Finish weaston General Metalwork Discussion 8 05-25-2007 11:31 PM
art work patgp WoodWorking 4 12-13-2006 09:37 AM
What's a good facemill to get? Loading General Metalwork Discussion 4 07-19-2006 03:19 PM
How does it work? tyler_derden TurboCNC 6 11-10-2005 05:23 PM
How well do these work? DAB_Design General Metalwork Discussion 4 02-18-2005 12:33 PM
