Old 01-16-2008, 05:04 PM
tikka308 is on a distinguished road
Correct use of parallels
Folks,
I'm going to be working a lot with aluminum pieces ~3" x 3" x 0.5". Unfortunately, the edges are never going to be perfectly square (but pretty close). When I try and use these in my vice with parallels, I'm having trouble with the parallel staying in place. Here's a video of it -http://www.youtube.com/watch?v=E3t3pfg-og8
is there a common solution short of squaring the edge? I'd like to keep it in a vice (versus fixturing).
Thanks!
Tormach PCNC 1100, SprutCAM, Alibre CAD
Old 01-16-2008, 05:12 PM
LeeWay's Avatar
LeeWay is on a distinguished road
What I have done is to install a softer set of steel jaws in my vise. Then I milled a shallow step in the top of them. This keeps my parts sitting up high and perfectly square and level with the table and the mill itself. I don't know if your vise has jaws or a place for them, but you could mill a step in the vise itself. Probably won't hurt anything.
Lee
Old 01-16-2008, 05:50 PM
dang's Avatar
dang is on a distinguished road
You could also place some springs in between the two parallels that would put pressure on them and keep them in place.
Old 01-16-2008, 08:37 PM
toastydeath is on a distinguished road
That's caused because the part is not square, and thus does not sit on the parallel. If you google around for the process to properly square up a block and following, a quick rap with a dead blow mallet will seat the part very firmly on the parallels afterward. Excluding jaw lift of course, if your vice is prone to such things.
Old 01-17-2008, 03:44 AM
philbur is on a distinguished road
Your video shows you giving the work piece only a mild tap while the jaws are relatively slack, this is not going to get it. Your technique is wrong. As you tighten the jaws they may tend to lift slightly. You should use the rubber hammer in stages as you tighten, using progressively stronger blows. Check the parallels at each stage.
Phil
Originally Posted by tikka308 View Post
Folks,
Thanks!
USB to Parallel Converter - Parallels are OBSOLETE bill south Machine Problems, Solutions , Wireless DNC, serial port 23 12-16-2008 07:11 PM
Wavy Parallels whats the deal with them maxboostbusa General Metal Working Machines 6 11-21-2008 08:51 PM
Having trouble keeping your Parallels in place during machining HelicopterJohn General Metalwork Discussion 18 01-17-2008 11:05 AM
Correct Pay?? j-radkemachine Employment Opportunity 70 01-21-2007 11:26 AM
Vises... parallels, soft jaws, accuracy, & sanity... InspirationTool General Metalwork Discussion 10 12-15-2006 09:54 AM
