| New Sieg / Grizzly X3 owner - obligatory questions I ordered a new Sieg X3 / G0463 from Grizzly last week. Like most new owners I have a few specific questions... Any help will be greatly appreciated. In return I will be posting a sweet CNC setup in the weeks to come ![]()
Thanks in advance, Neil |
| Howdy Neil, I can't really help you with the servo set-up, I used steppers (425 oz/in for x & y, 640 oz/in for z). Here's a link to a servo x3 video I saw the other day. It's ALIVE!..... uh almost. (x3) I haven't done my home switches yet. I got a 5 inch vise from enco for mine. It's kinda big (tall) even without the swivel base. I may buy the 4 inch vise later. My thinking was to get a vise that was not bigger then my smallest axis travel (I don't know why ).Later, Jack
__________________ Walking is highly over-rated |
| G'day Neil I know nothing of those servo motors so will not display my ignorance by commenting on the first two questions. I have home switches on the X and Y axis. "Photo Interrupters" which have the advantage of good accuracy and repeatability. Also of very small size. This means I was able to mount them right under the table in a very protected position. They both are fixed on to the respective ball nut mounts. Very protected from coolant and swarf. Being one switch per axis is an advantage (less wiring and inputs) and tabs placed to activate them at each end of travel. Below a couple of pics to help with description. With the Vise all I will say is don't get the cheapest you can. I think the bearings in the spindle are adequate, however I have read that the grease used is not the best and would benefit from being repacked with a quality bearing grease. Greg . |
So I've seen that most people are using steppers around 425-500 oz/in on the X/Y axis, but is that continuous hold or peak torque? And either way, would you have a datasheet for your steppers, so that I could compare it to my Globe motors?
I've heard with the right electronics (Omron signal amplifier), you can get repeatability of 0.0002" with those. I was always under the impression that they would get coolant and chips all over them, but it seems you've found a way around that. Looks like I'm going to be implementing the same setup. Thanks again for sharing the information.
My first big job is to make some pillow blocks to mount an engine to my ultralight airplane, and a few thou won't make a difference. I plan to buy a decent vise eventually, but I won't be able to afford it for at least a year. I've spent enough on the mill and airplane parts in the last few months ![]() If you have any more pictures of your mill, please feel free to post them |
| Here's some links: 425 oz/in specs http://www.kelinginc.net/KL23H286-20-08B.pdf 425 torque curve http://www.kelinginc.net/KL23H286-20-8BT.pdf 640 oz/in specs http://www.kelinginc.net/KL34H280-45-8A.pdf Enco precision milling machine vises http://www.use-enco.com/CGI/INPDFF?P...PARTPG=INLMK32 I got the 5" (425-7250) without the swivel base. The 4" vise (425-7240) may be my next vise buy. Good luck, Jack
425 oz. in @ 0 RPM (continuous holding torque) 127 oz. in @ 300 RPM continous, = 60 inches-per-minute 42 oz. in @ 900 RPM continuous, = 180 inches-per-minute My Globe motors with 2.8:1 timing belt reduction make 60 oz.in. at 1000 RPM so they may be ok. Torque also goes up the slower they turn. I'll probably crunch some more numbers tonight. Oh yea, one other question... Can this mill do really fast feedrates for G00 rapid movements? If so, how fast?
| Neil_J My Super X3 factory CNC conversion 4 axis. Standard steppers for factory conversion - someone will know what they are. May rapids are 2500mm/min in X and Y and 1450 in Z (cos I haven't fixed a resonance problem yet.) A-Axis: I don't know how many degrees/minute. Haven't measure it. For au$130 I boughjt a nice clamp kit in a red plastic hanging frame. Takes up less space than a vice. I have a 4" tilt vice i use occasionally. I visited Orlando 5 years ago. International Airport layout clear since google earth used to view it. Loved driving on the wrong side of the road.
__________________ Super X3. 3600rpm. Two possible way to fix things: The right way or the other way. |
#10
bah! My car gets 40 rods to the hogshead and that's the way I like it! |
#11
| Factory conversion limits Z travel. Longer strut required and refixing. I'm fixing mine now. Accuracy within specifications or better with a bit of fine tuning. Compatibility of BOB can be a problem on some PC's. Spindle speed control from CNC is unserviceable IMHO. They got it wrong. If you have no tool changer this just means simpler programs and you push your own start button and select your own speed. About time you guys started making low cost light aircraft out of plastic. Rivets are a thing of the past, but going too hi tech is hitting a golf ball with a sledge hammer.
#12
| To pull this thread back on topic, I get my mill tomorrow It's about **** time too, I've been without one for too long. |
| Sherline, Grizzly, Harbor Freight Sieg lathe | twocik | Mini Lathe | 35 | 06-20-2007 02:24 PM |
| Grizzly G3102 conversion questions, servos, steppers, breakouts and more. | turbostang | General Metal Working Machines | 4 | 05-03-2007 10:19 PM |
| sieg X3 questions | daedalus | Benchtop Machines | 0 | 10-21-2006 06:02 PM |
| Opinions? Grizzly G1005Z vs. Sieg X3 | whelzorn | Benchtop Machines | 2 | 07-20-2006 08:28 PM |
| Sieg X3 Questions??? | jer29_11_13 | Benchtop Machines | 0 | 08-09-2005 04:40 PM |
