| locknut for bearing preload Is there a special kind of nut you use for this, and what's the advantage of using it versus a simple hex nut? Does it make a difference to use a fine thread or coarse thread? Thanks. |
| Threaded nuts are not really the correct way to preload bearings. However I guess we all use them. The finer the thread the fine the adjustment of the preload. Also using a second nut to lock the first will usually upset the adjustment of the first and is not the best method. The nut thread and faces should be lathe cut as should the shaft thread. |
| Why is using a nut wrong? Is this because the nut is not square to the face of the bearing? What if I used a square spacer between the nut and the bearing? |
| Why would a nut *not* be square to the bearing? |
| Why would it be square. If the thread is lathe cut, yes, if you drill a hole and use a tap almost certainly not. Phil |
| Even a fine thread is quite course for fine adjustments of load. Also how will you actually know what the preload is? Forget a torque wrench, you would have to know the frictional resistance to rotation between the two thread halves. Using a nut isn't wrong. it isn't the correct way, that's not the same thing. Setting the preload to high shortens the service life of the bearing. In a worst case this could be from 10 years to 10 minutes or more probably in a hobby environment from 50 years to 20 years. So careful use of a nut, although not the correct method, can still produce an acceptable result. Phil |
| hey, even if it gets me just 1 year of service, I'm happy. I can just replace the bearings for $13 a pair in 10 min, rather than spending days preloading high quality bearings costing many times that amount. Can you also not experimentally determine the preload? For example: Get a precision spring of a known K value, and place it in between the two bearings you're using and on the same ballscrew. Using the K value figure out how much deflection of the spring you need for the preload you want. Tighten the nut with a torque wrench until the desired deflection on the spring is reached. Note the amount of torque needed, and this should be the amount of torque needed to preload it on the real bearing block |
| Bering nuts are ground square to the threads on their contact faces. A precision bearing pair has the preload ground into them. No mater how tight you tighten you get the same preload. On all tapered roller setups and some non-precision angular contact setups preload is controlled by how tight you screw it down. Consider drilling a hole through the side of the nut and putting in a small set screw to lock it on the shaft (brass tipped set screws work great for this). This will give you better control over the preload than using 2 nuts. Bob
__________________ You can always spot the pioneers -- They're the ones with the arrows in their backs. |
#10
| where can I buy square ground bearing nuts for metric threads (12mm) on the internet? I guess I can grind them myself, but that takes a lot of work. |
#11
as long as the bearings run smooth you should be ok |
#12
| if your shaft being preloaded does not heat up then all you have to do is preload the bearings just till there's no end play if the shaft heats up and the bearings loosen with the thermal growth of the shaft then you will have to tighten the preload up so at that temperature there is no end play if the shaft heats up and the bearings tighten with the thermal growth then you will have to loosen the preload so there is just no end play at that temperature |
| preload on spindle bearing | adryan | General Metal Working Machines | 7 | 06-21-2010 06:59 PM |
| Bearing Preload w/Lovejoy Connector | rcazwillis | Linear and Rotary Motion | 21 | 07-23-2006 06:43 AM |
| preload ? | andy55 | Linear and Rotary Motion | 5 | 01-04-2006 07:28 PM |
| strange bearing preload thread on ballscrew | mxpro32 | Benchtop Machines | 14 | 03-22-2005 02:23 PM |
| strange bearing preload threads on ball screw | mxpro32 | Mechanical Calculations/Engineering Design | 1 | 03-10-2005 09:07 PM |
