Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: Picture to 3D to G-code
    Dec 2007
    Hey,
    Thought I would post this question here. I am not having any luck finding the answer through searching here and Google.
    One of my eventual goals once I get my mill CNCd is to take a picture of something, convert it into a 3D drawing and then convert that to G-code for milling into a chunk of aluminum. My first goal is to take our unit coin (military unit) and make a larger 3D version of it in aluminum. The coin itself is around 1-1/2" in diameter. I would make one around 3" in diameter.
    What programs (cheap) would do that?
    I'm already getting somewhat familiar with TurboCad Deluxe 10. I found a TurboCad Pro 12 and Cam package for around $200. Would that software do what I want to do? I could not find anything on the TurboCad site that showed me that.
    Mike
    Dec 2007
    Good Golly.
    After searching around last night for two hours, I found an excellent thread on CNCzone and other hits on Google after a 5 minute search.
    Sigh.
    Here is the cnczone thread:
    3D GCode from greyscale?
    Although that never really said whether TurboCad Pro 12 would work...
    Mike
    Registered Regnar's Avatar
    Mar 2006
    I have never done this but hope it helps you out http://vectric.com/forum/viewtopic.p...r=asc&start=45
    Mar 2003
    Shelby Twp, MI....USA
    Quote Originally Posted by BrassBuilder View Post
    Mike
    Not likely. going from a picture to a 3D model is not as simple as you might think. You'd probably be better off either probing or laser scanning it. Take a look here.
    http://www.david-laserscanner.com/
    Mar 2006
    I was going to mention the same thing as Ger but I couldnt find the link.
    For the milling process you could use meshcam or cut3d both are affordable.
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    Or, the new MACH3 plug-in. You can get the scanning and also the machining. Haven't tried it yet - but may need to take the scanned results ( does Mach create point clouds) through another program. Anyway, well worth a look at the Mach3 program.
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Nov 2007
    Yes, laser scanning is the only method I know of to get something like that eventually converted into an IGES file (I work at Toyota with this stuff every day).
    It would be very time consuming and tedious, but if you wanted to, you could bring a good pic of it into AutoCAD or some other 2D drafting program, then proceed to create lines on top of the imported pic. You'd be creating more of an emboss than a true 3D replica, but it's very doable.
    Jul 2007
    Look into Bobcad. They have a program that goes with their Cad/Cam program that turns pics into 3d images and Code. I think its called ArtCam.
    Dec 2007
    Thanks everyone!
    You have given me more options to think about and mull over.
    Mike
    Registered LeeWay's Avatar
    Jun 2004
    I use Turbocad pro 11.2, but without the cam package. The cam side is still only 2D or 2.5D, so it won't like doing what you are trying to do. The pro version does draw 3D pretty well though. A little higher learning curve on the 3D side of the tools, but if I did it, you can too.
    About the easiest way to do this other than probing or laser scan it to scan it in as a bmp, then just redraw over the top of it. If it is mostly straight geometry and text, then you should have little trouble with it. Once you have a simple line drawing, you could even use a 2D program like Sheetcam or many others to pocket or cut around your objects to a depth that you wanted.
    You can also take a picture of it or a scan and import into a graphic program (I use Corel Draw and Photo Impact.) You will have to play around with blurring and shading, but then you can import into Meshcam and it would cut a likeness of it. May be good enough for what you want. That goes faster than redrawing, but you don't have as much control over the finished drawing.
    Why don't you load the image you have here? We could then see what obstacles you might face.
    Lee
    Mar 2005
    Most decent 3D CAM programs will do height displacement of greyscale images fairly well, you'd probably have to tweak your image to get something you'd like.
    That'd be the easiest unless you had an existing model to copy and could scan it.
    Aug 2007
    Delcam offers Artcam that is a great product, maybe a little pricey for the home user
  • Page 1 of 2 12 LastLast
    1. picture file to G-code
      By zachjowi in forum LinuxCNC (formerly EMC2)
      Last Post: 12-22-2009, 12:26 PM
    2. From a picture to the CNC
      By iipeacefrog in forum Rhino 3D
      Last Post: 10-10-2007, 02:12 PM
    3. Encrypted cutting code in this picture ( Amazing)
      By ynneb in forum CNCzone Club House
      Last Post: 06-18-2004, 05:26 AM
    4. How Do I Get A Picture Under My Name?
      By CNCadmin in forum CNCzone.com FAQ
      Last Post: 04-12-2003, 10:50 PM
