Try here
http://cgi.ebay.com.au/HEAVY-DUTY-QU...QQcmdZViewItem
Hare and Forbes probably carry it as a spare part as well.
Hello,
I am new here and have searched the forums but can't seem to find any previous reference to this questons.
I have a Rong Fu RF-31 copy and the Spiral Sprinl that is used to return the spindle back to the top (idle postiion) is broken.
Any ideas on where I could find spares of this kind in Australia?
Regards
BTU![]()
Try here
cheers,
Rod
Perth, Western Australia
Rod,
Thankyou very much. Hare and Forbes are one of my favourite shops.
Regards
BTU
Yeah mine too.![]()
cheers,
Rod
You can also get Ru Fong parts thru Enco
http://www.use-enco.com/CGI/INSRHM
Jack&Master
FYI,
I ordered a RF-31 quill spring but found it was too wide, 19mm , My mill ( i have since found out) is a RF-20 or MD-20, very similar in appearance to an RF-25/31 but must be a bit smaller or something. Anyway the quill spring i required was 5 mm wide. www.hareandforbes.com.au have a pedistal drill called a PD-26 and the quill spring from that item is a near perfect match, so I have installed it on my MD-20 and all is good again.
BTU![]()
Did you break it taking it off like I did?
"A-ha Says I, a keyhole!. Now why did I not think of that before I used excessive force?"
Dan_the_Welder,
No, mine was already broken, I was origonally going to just use the reamining spring as best i could but is was broken almost in the middle so it was not an option. but installing the new one was a very dangerous business indeed.
The first attempt was with saftey glasses only but after a bit of a incident and a little loss of blood, I decided to wear riggers gloves as well and after a bit of muching about managed to correctly seat the new spring.
All's well that ends well.
BTU![]()
