Results 1 to 6 of 6
Thread: what is the possibility of turning on mill
    Apr 2005
    I have attempted to search but the three letter limit for searching doesn't do well with "mill". I am looking to purchase a small mill in the range of about $600. Thinking from harbor freight (simply due to having one close) I am also going to be in need of turning a few smallish pieces and was wondering about the possibility of pretty much attaching a traditional three jaw chuck up to the spindle of the machine. I have limited access to a full shop for producing any adapters etc. so that should not be a problem. I am thinking create a mounting plate with the matching taper the drawbar can thread into. From this point just bolt the chuck on. I am only thinking of turning maximum about 6" diameter parts and much more likely around 2" Dia. The length of the part would never be over an inch or so. I figured i could just make a tool holder to then mount down to the bed of the mill and use the y and z axis for translation. Is this common practice or has anyone even attempted such a thing? can you see any immediate problems with this?
    Just to add I won't be planning on cutting threads so that won't be an issue for me, maybe later when i go to adapt the mill to be cnc but not now.
    Jul 2007
    The max cutter diameter on a X2 is stated at around 1" depending on where you look, personally I dont think that even if you adapted a lathe chuck to mount up the machine would handle it very well. Even the X3 probibly wouldnt like it. Maybe if you had something like a Bridgeport style knee mill it could be done. A benchtop lathe would be a whole lot safer and more practical and besides they arent all that expensive. Just my 2 pennys though.
    Oct 2005
    Thumbs up
    Sure mills can be used as lathes.
    I figure it's just a vertical headstock.
    these links show a mill being used as a lathe in two configurations.
    [ame]http://www.youtube.com/watch?v=2Munq_hXxTs
    [ame]http://www.youtube.com/watch?v=wbfXXeiSHsw
    Mark
    microtools.ca
    Jul 2004
    Everyone hates 3n1 types of mill-lathes, but since that seems to be what you are asking, here goes anyhow...
    You could step up your price range a bit ($1300), and buy what by all reports is a decent chinese lathe: the Sieg C6. Grizzly sells a version of this with the X2 milling head attached as a combo mill-drill (G0516). This would allow you to do everything you want now.
    In the future, when you decide that you can't stand a mill-lathe combo anymore, you can strip off the X2 head, and still have a decent lathe (unlike some of the other combos where you get a sucking lathe and a sucking mill in one package). You can either buy a base for it at LMS so you have a complete mill or just buy something better.
    http://www.grizzly.com/products/Comb...tachment/G0516
    It really sounds to me that what you really need is a lathe, not a mill.
    Apr 2005
    metalbyter, you have the right idea in that second video you have posted. The only thing i was wondering about is how the workpiece is being held, hence the suggestion on my part of making a taper backed to a three jaw chuck. Any ideas of how they achieved this in that video, or do you know what size of machine that is?
    I don't want one of the mill-lathe combo machines at all, i've heard so many other people complain about them. I am looking at the majority of my use will be as a mill just rare pieces that would be much easier on a lathe.
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    Turning 6mm diameter is viable (held in a collet).
    Adding a chuck adds too much weight and too much extra length.
    Turning 6" diameter will be an effort in futility (even in a Bridgeport).
    The C6 lathe/mill will do what you want to do for cheap.
    Better yet get a lathe and a mill.
    www.integratedmechanical.ca
    1. 5fth axis DIY possibility?
      By Bloy2004 in forum WoodWorking
      Last Post: 07-06-2008, 05:18 PM
    2. Mach3 Mill.... Motors not turning.
      By junior85 in forum Mach Mill
      Last Post: 05-29-2007, 02:45 AM
    3. New Drive Possibility ?
      By Michael Kearsey in forum General Electronics Discussion
      Last Post: 06-15-2005, 06:06 AM
    4. Possibility of Machine Kit Cutting
      By Sinkoumn in forum DIY CNC Router Table Machines
      Last Post: 05-05-2005, 08:27 AM
    5. Possibility of 5 axis??
      By calkai1 in forum DIY CNC Router Table Machines
      Last Post: 04-29-2004, 08:21 PM
