Old 12-10-2007, 02:23 AM
twocik is on a distinguished road
Y Axis Slipping ??
I'm experiencing some serious play in my CNC X1. I can't seem to locate the problem and need some help. All of my aluminum parts are missing steps and look pretty bad.
I've tried to adjust the shaft collar and work the play out in the gibs (100%
perfect on the gibs). I can still push and pull on the Y table and fell the it move about 2mm - 4mm. I'm pushing in a forward to backward motion (toward and away from the column).
I've uploaded some pictures of my parts and if you look closely you'll see the offset and a really bad looking layers surface. I've lower my feed to 3 ipm and reduced my depthInc to .04 per pass, so the only thing I can come up with is the play in the Y axis, but can't figure out how to correct it.
Any advice would be greatly appreciated.
Chris
ID:	48245   Click image for larger version
ID:	48246   Click image for larger version
ID:	48247   Click image for larger version
Old 12-10-2007, 03:25 AM
cncbasher is on a distinguished road
you may be running the controller at too high a step rate , or even the torque rating of the steppers may not be correct , so more information on your setup should help to narrow down the problem , you may also have resonance or vibration problem , excessive play etc in your z axis , can all give this sort of result
which motor and controller are you using etc , software ?
Old 12-10-2007, 04:47 AM
j.guenther is on a distinguished road
I had a similar problem with my CNC X1 on the X axis. The problem was that the X axis lead screw nut was loose. Since you say you can actually move the table by applying force either toward the column or away from the column there is something loose some where. I would check the nut to make sure it is securely fastened to the base. You should also check the preload on the bearings, if you have bearings on the lead screw. Check the backlash adjustment on the nut as that might be a source of the problem, but I doubt that 3 to 4 mm of movement would be caused by wear in the nut.
John Guenther
John Guenther
'Ye Olde Pen Maker'
Sterling, Virginia
Old 12-10-2007, 04:50 AM
LeeWay's Avatar
LeeWay is on a distinguished road
It could be power, rigidity or backlash in the nuts or any combination of these.
More info about the type of motors, drivers, power supply, screws and nut type would also help.
Sometimes slowing things down is not the way to go either. Especially with different grades of aluminum. If everything is running too slow and there is slop somewhere, you will get a lot of catching and jerking with vibration.
Lee
Old 12-10-2007, 04:58 AM
philbur is on a distinguished road
The offset doesn't look like backlash. Backlash will give you a step at the change of direction. Are the inner and outer diameters the correct diameter and are they circular. Could be stepper calibration. when you say that you can move the y-axis 2 to 4 mm is with the machine powered up. With ballscrews and without power-up it is quite possible you can move the table by hand. How did you produce the G code, have you looked at it to see that it is correct. The rough surface finish on the walls of the component looks like cutter deflection to me. Did you do a finishing pass or was it cut as a slot.
Just some thoughts
Phil
Old 12-10-2007, 05:29 AM
Lexx0001 is on a distinguished road
I'm probably missing something, but 2 to 4 mm play seems rather excessive. I would think with that much give, the Y axis is being pushed and pulled by the end mill instead of the other way around. The motor mount to the slide may not be tight, coupler could be slipping, or the nut could be loose inside the saddle.
I guess to help narrow it down, when you can move it, does the screw move with the saddle, or stay with the machine?
Just my 2 ¢
Old 12-10-2007, 06:00 AM
Rally's Avatar
Rally is on a distinguished road
I would start by looking at the Nut and where it is mounted to the Machine.
If my Eyes are not cheating me you should also change the e-mill it looks like it is smearing instead of cutting.
The table should not move no 4mm no matter what!!
I do however have to agree that it looks kinda smooth for a backlash problem.
Old 12-10-2007, 06:06 AM
A "normal" ballscrew is not self-holding. For example a mill head can fall under its own weight, with the power off the stepper. Ask Tormach PCNC1100 owners.
So with the power off the y-axis motor it is quite possible you could move the table by hand and turn the ball-screw. Depends on how hard you push.
Phil
Old 12-10-2007, 06:18 AM
omkargupta is on a distinguished road
PLEASE TIGHTEN THE CHECKNUT OF BALL SCREW. Either Change Ball screw
Old 12-10-2007, 06:50 AM
LeeWay's Avatar
If the machine is powered up and you can still move the table, then it could be a loose drive nut, screw mount, coupling, or weak motors.
Table movement with no power is inconclusive because is possible to move them unless they are something like threaded rod and have a very fine thread. More input is needed.
Lee
  #11   Ban this user!
Old 12-10-2007, 11:17 AM
Wow you guys work fast!! Sorry I wish I had Ball screws, but I don't (stock lead screws).
My machine is bolted down in my water tight enclosure, so I don't believe I'm getting that much vibration. As for the Z axis, adjusted this before anything (works great).
- Harbor Freight X1
- Hobby CNC Board & Steppers 200 oz Kit
- Steppers running at low speed () for more torque
- Running Turbo CNC for my controller software
- Extended X & Y axis tables
- Fusion Motor mount kit
- Using 6061 aluminum
- 3/16 2 flute carbide end mill
j.guenther
I'm going to check again. The only thing I wish I would have thought of before I made this enclosure is, how am I going to get this in & out for maintenance.
"You should also check the preload on the bearings, if you have bearings on the lead screw. Check the backlash adjustment on the nut as that might be a source of the problem, but I doubt that 3 to 4 mm of movement would be caused by wear in the nut."
I'm using a trust bearing setup, but never thought about the backlash nut. The last time I played around with the nut I broke it and had to buy a new one. I'm going to take the mill out of the enclosure again and try and find this problem.
"Especially with different grades of aluminum. If everything is running too slow and there is slop somewhere, you will get a lot of catching and jerking with vibration."
6061 aluminum, adjusted the tables with an indicator (.02mm off ).
"Are the inner and outer diameters the correct diameter and are they circular. Could be stepper calibration. when you say that you can move the y-axis 2 to 4 mm is with the machine powered up. With ball screws and without power-up it is quite possible you can move the table by hand. How did you produce the G code, have you looked at it to see that it is correct. The rough surface finish on the walls of the component looks like cutter deflection to me. Did you do a finishing pass or was it cut as a slot."
Yes they're circular, but the center is offset. I've cut the part out on a soft piece of wood and came out perfect looking. So I'm guessing with harder material, this is what's pushing my part around. No ball screws. I produce my G code thru CamBam, but this isn't the problem. Well I didn't get around to making a finish pass, only because the part was offset pretty bad and couldn't be saved.
ID:	48286   Click image for larger version
Name:	Mill Coolant System 2.jpg‎
ID:	48287   Click image for larger version
Name:	Mill Coolant System.jpg‎
  #12   Ban this user!
Old 12-11-2007, 12:16 AM
Ok so just before I started to take apart my mill to locate this problem, I took a closer look at the 6061 aluminum plate that I cut it out of. If you take a close look, you'll that the 3/4 of the parts walls look really really smooth. I'm kind of stumped now. I've uploaded some pictures to see what I'm seeing, any ideas at all pleas feel free. ???
My guess -
Since there is a play in the X axis (2mm - 4mm), when the end mill was cutting along its path, the end mill stayed snug against the side that was pushing on it.
What gave me this idea is on the part that was cut out in my first post, you'll see the walls on the right side are not bad looking at all, but on the original raw material you'll see the layered surface were that part was cut from. It's weird I know, the side that came out nice on my part is the side that looks like crap on the left over piece of raw 6061 material clamped to the table and vise versa for the other side.
So it's definitely from that damn Y axis slipping, I really need to find what is going on under my mill. I'm just about to take it out of the enclosure and try my best to find the problem.
Name:	DSCN6522 copy.jpg‎
ID:	48321   Click image for larger version
Name:	DSCN6523 copy.jpg‎
ID:	48322   Click image for larger version
Name:	DSCN6524 copy.jpg‎
ID:	48323   Click image for larger version
Name:	DSCN6525 copy.jpg‎
Fadal Low Speed Belt Slipping BAD DOG Fadal 22 11-29-2009 10:50 PM
stepper motor internals and drive slipping help rally.sport Stepper Motors and Drives 1 01-03-2007 03:30 PM
EZTRAK Y axis loosing position, "slipping" melamark Bridgeport and Hardinge Mills 7 12-18-2005 01:23 PM
Boss z-axis belt slipping jderou Bridgeport and Hardinge Mills 13 06-01-2005 01:08 PM
Harbor Freight Band Saw Blade Slipping barkster Benchtop Machines 6 04-26-2004 12:20 AM
