Results 1 to 7 of 7
Thread: CNC Control Panel and Pendant Functions
    Feb 2006
    I've just bought myself a lovely new Birmingham knee mill, which I will be immediately doing a 3-axis CNC conversion on. As part of the conversion, I want to build a nice control panel, which will house the computer display (LCD panel), keyboard, and a nice assortment of controls for common operations, and simple manual operations. If it makes sense, I'll also make a pendant, wireless if that has benefit. I'll be using Mach3 for the controller.
    So, the question is: What functions does it make sense to put on the control panel and/or pendant. Some are, I think, obvious:
    E-stop
    Spindle speed/direction controls
    Jog controls for all axes (joystick?)
    Coolant on/off control?
    What else should I include? Being an electrical engineer and a software guy, I have no problem with putting some "intelligence" in the control panel, if it's used to include some useful functionality.
    I've never used a "real" CNC machine, just my self-converted X2 mini-mill, so I'd be interested in learning what kind of front panel functionality real CNC machines have as well.
    Let's have some ideas!
    Regards,
    Ray L.
    Jul 2007
    Hoss the X2 magician on here has a controller for his Mach 3 setup if you havent seen it you might want to check out what functions his has just to give you a baseline. His site is www.hossmachine.com
    Feb 2006
    Quote Originally Posted by maxboostbusa View Post
    Thanks, that does help some, but he doesn't really detail what all the controls are. I can make out some in the photos, but not all. Hopefully, he'll respond to the thread with some suggestions.
    Regards,
    Ray L.
    Registered The Blight's Avatar
    Sep 2006
    Denmark
    Hoss ATC Project
    Hoss posted an explenation of the control panel in this topic. There is one picture with a great view over the control panel where you can also see the labels for all the buttons and switches on it.
    Gold Member hoss2006's Avatar
    Apr 2006
    I'll be building a new control panel during xmas vacation.
    Got my inspiration from the Machmotion panels.
    Will add a built in LCD screen like theirs.
    I'll be adding a LOT more switches and stuff than they use.
    I like the joystick for rapiding around the table but going to add a Manual Pulse Generator.
    Merging the old control panel with the new one, keeping the jog buttons
    and feedhold buttons (locking momentary switches)
    Adding a bunch of toggles for Op Stop, Block Delete, Single Block, etc.
    Also selectors for Feed Rate and Jog Rate.
    Switches for manual Power Drawbar and Flood Coolant control.
    And of course Cycle Start, Feed Hold and E Stop.
    Really just needed something bigger to house all the electronics and get away from my rats nest.
    Hoss
    Feb 2006
    Quote Originally Posted by The Blight View Post
    Hoss ATC Project
    Thanks! That does help!
    Feb 2006
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Hoss,
    I will look forward to seeing what you come up with. I'm sure you'll keep us posted! :-)
    Regards,
    Ray L.
    1. CNC Control Panel And Pendant Functions
      By SCzEngrgGroup in forum Bridgeport and Hardinge Mills
      Last Post: 08-28-2009, 11:21 AM
    2. Anybody build a pendant/control panel with a PIC ?
      By per.e in forum PIC Programing / Design
      Last Post: 05-10-2009, 10:27 PM
    3. stepper control boards and their functions
      By cyclotron in forum DIY CNC Router Table Machines
      Last Post: 03-03-2007, 12:39 AM
    4. My DIY control panel
      By DennisCNC in forum CNCzone Club House
      Last Post: 10-02-2006, 11:24 PM
    5. Building my control panel
      By ChrisJ in forum General Electronics Discussion
      Last Post: 03-02-2005, 09:09 PM
