Old 11-29-2007, 10:22 AM
djh82uk is on a distinguished road
Kress Collet/Chuck Problem
Heya Guys
I have a Taig with a Kress Spindle fitted, but I have a problem, I need to do some drilling, I only have 3.175mm and 8mm collets however, and don't fancy having to buy £230 worth of collets just to do some drilling.
I have all the collets for my ER-16 spindle, but cannot use it as it sticks out a diffeent amount from the column, so would mess up my offsets.
Any ideas? I thought about a pin chuck, but they cannot hold the size drill bits I want (2mm, 3.2mm, 3mm, 4mm, 6mm, 10mm).
Any other ideas? I don't mind having to buy some sort of a chuck and a collet for it if it won't fit mine.
Any advice appreciated
DJH
Old 11-29-2007, 01:46 PM
kreutz is on a distinguished road
Originally Posted by djh82uk View Post
Heya Guys
DJH
Can't you use the same drill bits used for PCb drilling? they all have 1/8" shank and come in different sizes.
Old 11-29-2007, 04:06 PM
to a certain extent that is what I do, but for when i need to drill holes a fair bit bigger than 1/8"?
then the problem arises again
DJH
Old 11-29-2007, 04:14 PM
DJH
In PCB manufacturing bigger than 1/8" holes are milled, maybe the same could apply in your case.
Old 06-29-2008, 12:37 PM
Tadas25's Avatar
Tadas25 is on a distinguished road
have you solved a problem with this kress router ?
I have same problem - I have 3mm collet, but I need 1 mm collet :/ Or better chuck holder for ER-16 collet's, but I can't find that :/
Thanx !
Old 12-01-2008, 01:23 PM
Quecomm is on a distinguished road
Hello here is a site that stocks Kress spindles as well as some parts including collets and the clamping nuts. The collets range is size from 1mm to 10 mm and they also sell a 9 piece set that comes in a wooden box to keep them together.
The name of the company is "Marchant Dice Ltd." and they are located in the U.K.
The currency conversion for pounds vs. dollars is about $0.65 per pound or for a one hundred pound order it will cost around $150.00 on average.
http://www.worldofcnc.com/main.asp?c...lling+Spindles
I hope this helps anyone who uses a Kress spindel.
Phillip (Quecomm)
Old 05-01-2009, 05:22 AM
*Registered User*
marchantdice is on a distinguished road
New Design Kress clamping nut
As a distributor of the Kress milling grinding spindles ( www.worldofcnc.com ), we have noticed another small design change to the Clamping nut...
The new stock bore is 8.4mm as opposed to the old 10.5mm this will restrict the choice of the larger collets (9.0mm and 10.0mm) the nut can be bore, take care as they a brittle....
Phillip (Quecomm)
Old 10-24-2010, 04:39 PM
NerdT1000 is on a distinguished road
Any word on using other type/brand collets for the Kress serias guys?
Old 10-31-2010, 06:43 AM
ozmos is on a distinguished road
Most probably they are DIN 6388 EOC 08 or EOC 10 type.
Old 10-08-2011, 04:15 AM
miopicman is on a distinguished road
Heya Guys
DJH
I have a power drill with a collar that fits the Kress bracked perfectly. I use this when I am using ordinary drills. It's a Bosch PSB600 RPE. See my movie at miopicman's Channel - YouTube
The movie is quite old now and I have since rebuilt 'The Machine' in steel.
Kress 800w router Bernard HURCO 10 01-28-2011 07:43 AM
Which collets to use with BT40 Collet Chuck JMFabrications General Metalwork Discussion 3 05-18-2009 08:21 PM
Expected runout from an ER32 collet chuck buckie555 General Metal Working Machines 10 04-01-2006 07:32 AM
buy Kress 900 in Europe ikkedus Mechanical Calculations/Engineering Design 5 01-28-2006 11:06 AM
Which collet chuck? Al_The_Man General Metal Working Machines 3 06-27-2004 01:11 AM
