Old 11-26-2007, 11:10 PM
cp465vw is on a distinguished road
how do you calculate steps
I have a taig mill with the deepgroove set up. I created a circle on mastercam inches and my mill does move in a inch circle.
I am using mach3 mill
Old 11-27-2007, 01:14 PM
project5k's Avatar
project5k is on a distinguished road
i guess i dont understand the question then, if you input an inch, and you got out an inch at the mill, wheres the problem, sounds like you already have the step calculation set up correctly...
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
Old 11-27-2007, 02:09 PM
sorry did not write the question right. ooops!
I drew a 4" circle and when it move the table it moves it much, much smaller.
I set a pen up yesturday and it seems to be about a half inch circle that is drawn by the mill. So i messed around with steps per in the motor tuning set up and got a bigger circle but still not 4". I am assuming that there is a calculation for steps per inch. I know the guy i got the motors has some where that it is 10 turns per inch. but how do I turn that into the calculation I need???
Thanks!!!
Old 11-27-2007, 04:26 PM
Robin Hewitt is on a distinguished road
Still a bit short on info for meaningful answers...
If you have ordinary microstepping drivers fitted, the switches on the stepper driver box determine the pulses per rev.
Multiply pulses per rev by the revs per inch and get pulses per inch.
Old 11-27-2007, 04:36 PM
acondit's Avatar
acondit is on a distinguished road
Your basic useable stepper is 200 steps per rotation. Multiply that by how many microsteps (if any) your controller produces. Multiply that by any gear or belt reduction ratio (for direct connect use 1). Finally, multiply by the number of threads per inch on you leadscrew.
(200 x Msteps x reduction_ratio x TPI) equals steps to move 1 inch.
http://www.alansmachineworks.com
Proper way to calculate steps/unit for belt drive? MrBean DIY-CNC Router Table Machines 31 03-30-2007 09:48 PM
how to calculate flex dertsap Mechanical Calculations/Engineering Design 14 04-17-2006 06:22 PM
Full Steps -vs- Micro Steps DJB282000 General Electronics Discussion 10 12-28-2005 11:25 PM
Calculate resistor value for g210 ??????? Biggermens Gecko Drives 0 04-25-2005 02:09 PM
How do I calculate this? CNCadmin Mechanical Calculations/Engineering Design 2 02-05-2005 09:24 AM
