Old 11-22-2007, 03:56 PM
Micro Rotors is on a distinguished road
HF 44991 X2 Mini Mill Motor Wiring?
Hello Guy's
I just assembled my HF 44991 X2 mill to a CNC version. I was wondering if anyone knows the motor wiring inside the box for the speed control? I misplaced the notes I had on that one. A picture of inside that box would be perfect.
Bill
Bill
Old 11-22-2007, 04:32 PM
dang's Avatar
dang is on a distinguished road
EDITED:
I'll post a photo in a few minutes.
Old 11-22-2007, 05:05 PM
dang's Avatar
Ok,
All three of the blue wires go to the Pot, #1 being on the slow end and #3 being the fastest.
Wire #5 goes to the Amber Fault Light
Wire #4 goes to the lower fuse connector
- Upper fuse connector goes to Lower Left E-Stop Connector
Wire #3 goes to upper left E-Stop Connector
Connectors:
White to White
Green to Green
Black to Black
As for Wire #1 & 2, I'm not sure, although I believe that they both go to the E-Stop so I suppose it doesn't matter.
Hope that helped. It's a pain in the rear. I lengthened my wires and disconnected my speed control box from the mill all together. When it was over and reconnected I think the whole ordeal took a couple of weeks off my life.
ID:	47229   Click image for larger version
Old 11-22-2007, 10:40 PM
Hi Dang,
Thanks, If you could ... please check these wires that connect to each other with plugs. I marked their location in your picture.
Bill
Bill
Old 11-23-2007, 06:47 AM
dang's Avatar
Those would be the wires marked #1 & 2 that connect from the board, directly to the motor. I told ya, this is difficult. Last time I thought they connected to the E-Stop. Anyway, they should connect to the similarly colored wires with the sleeved male/female connectors and just run right out the other, skinnier tube to the motor.
I hope that was correct.
*If the wires aren't similarly colored, then hit them with a multimeter to determine which of them is Negative or Positive.
#1 is negative.
#2 is positive.
The other, (green) is ground.
Old 11-23-2007, 06:49 AM
dang's Avatar
You may wanna get a bunch of spare fuses when you 1st put charge back through the system.
Mini Mill Motor Flange type PIngels Benchtop Machines 0 04-28-2006 09:32 AM
Mini Mill Motor Size jjwl89 Benchtop Machines 2 08-10-2005 03:24 PM
HarborFreight Mill 44991 Brass_Machine Benchtop Machines 1 04-12-2005 07:24 PM
It's ON! (HF mini-mill #44991) Nonoriginal Vertical Mill, Lathe Project Log 3 03-19-2005 08:16 PM
Mini Mill Motor Amperage jjwl89 General Metal Working Machines 0 06-24-2004 06:56 PM
