Old 11-16-2007, 10:35 AM
jaru-eri is on a distinguished road
Oil or grease on axis?? What´s best??
Will it be better and last longer with mos2 grease on the axis threads or will oil be the best choice? Or maybe a mix of both?
I have a Taig mill.
Any suggestions?
Old 11-16-2007, 01:06 PM
maxboostbusa is on a distinguished road
I have used mobil 1 10w-30 and white lithium grease on my ways and feedscrews. Both work well, the grease lasting a little longer maybe. The main disadvantage of the grease for me as opposed to the oil is it seems to stick chips to it alot worse. I really dont like running chips through the feedscrew nuts or between the ways and gibs for that matter, so I use oil for the most part now. Just have to do it a little more often seems like. Just my 2 pennys though
Grease nipples on VF0 x axis? UBRacing Haas Mills 5 07-08-2007 10:40 AM
#1 grease? Have Blue Tree 11 12-03-2006 08:24 AM
M6 x 1.0mm grease fitting N4NV Mechanical Calculations/Engineering Design 5 03-31-2006 04:03 PM
oil or grease? hpghost DIY-CNC Router Table Machines 2 08-30-2005 02:20 PM
grease?? DLMACHINE Machine Problems, Solutions , Wireless DNC, serial port 0 04-22-2004 12:27 AM
