Old 11-07-2007, 09:17 AM
DICKEYBIRD is on a distinguished road
X3 Gear Lubrication
I've had my X3 for almost a year and am curious what you fellers do to lube the spindle drive gears.
I did the break-in procedure as specified in the Grizzly manual and also removed the side panel for access to spray all the gears down thoroughly with white lithium spray grease. There's no reason to suspect any trouble, no new noises, etc. It has not been converted to CNC so it doesn't wail away for long periods but I have been doing some aluminum work with the speed up high lately. What say ye gurus?
Basic Bevel Gear - Milling a valley for gear teeth ngr1 General CAM Discussion 10 04-05-2012 09:55 AM
X2 maintainance/lubrication Pretorien Benchtop Machines 3 11-08-2007 06:17 AM
Lubrication bohica Industrial Hobbies (Support forum) 17 04-29-2007 01:13 AM
Spur Gear / Gear Rack ckrantz Linear and Rotary Motion 12 12-06-2006 11:06 PM
Lubrication BeerFizz Benchtop Machines 5 11-09-2005 06:25 PM
