Page 1 of 3 123 LastLast
Results 1 to 12 of 28
Thread: PSI required to clear chips?
    Dec 2006
    What is the general PSI required to clear chips from a workpiece? I've got a Taig CNC mill, and I'm tiring of hovering over the machine with a vacuum wand and a can of WD-40... I'm looking at the Spra-Kool Midget Mist unit from Little Machine Shop. I'm told that the min 30psi for that unit will deliver the coolant mist, but likely won't do much to clear chips, so I'm trying to figure out what else to get and/or hook up to clear the chips.
    Thanks!
    Registered teamtexas's Avatar
    Aug 2007
    30 psi directed at the cutting tip should do a fair job of debris removal. I use a compressor with a 90psi out put but I reduce it down alot at the machine. Not sure of the actual amount being delivered. A small air compressor (pancake style) would do an ample job if you don't want to take the chance on the mist. Put something like a 1/4 inch ball valve at the end to control the flow.
    Dan
    Oct 2005
    30 PSI should remove aluminum no worries. I use 20PSI as I do not want to spread the swarf all over my shop. Make sure the air nozzle is close to the cutter and you should have no problem.
    cheers,
    Rod
    Perth, Western Australia
    Dec 2006
    Great info - thanks for the help!
    I've ordered the 30psi spray unit, and will play around with potentially restricting the airflow a bit to keep from trashing my basement work room!
    I'm now committed to sharing my work room with my 2hp Craftsman pancake compressor - there goes my hearing... Anyone have any good tips on reducing the racket a bit? Is there any effective kind of noise-reducing enclosure or such that one can build for the compressor? I generally do my milling at night after the wife and kids are in bed, so I can't locate the compressor in another room or such, as it'd disturb them. Outside isn't an option, as then the neighbors would be waking the wife and kids up anyway, knocking on the door to tell me to cut the racket... :-)
    Thanks!
    Jul 2005
    Put your compressor inside a box lined with shag carpet, or other deep pile carpet, and it will cut the noise dramatically. Depending on how hard the compressor is working it may tend to overheat if the box is closed and in this case you have to get a bit more sophisticated. Put ventilation tunnels into and out of the box with carpet covered baffles so there is no straight path in or out and get a bathroom vent fan to draw cooling air through the box. When the sound has to go around many corners and bounce off surfaces that are poor sound reflectors it gets diminished.
    Oct 2005
    Geof is on the money there. Only thing I can add is a rubber mat on the floor or at least the legs to absorb the vibration.
    cheers,
    Rod
    Jul 2005
    Quote Originally Posted by Rodm1954 View Post
    Hanging head in shame....yes I missed that.
    Which is inexcusable really considering I installed a diesel genset in my home shop and had to mount it on a big block of concrete with rubber isolators to stop it bouncing the floor up and down. The noise I controlled with the baffled box...a BIG box!
    Dec 2006
    Heh Heh - if you can build an effective baffle box around a daggone diesel generator, it gives me hope that I may be able to sufficiently quiet my 2hp compressor to the point that I can reach old age with my hearing intact! :-)
    Jul 2005
    Quote Originally Posted by jim_stoll View Post
    eh, eh, speak up boy!! I can't hear you.
    Not to suggest I have reached old age yet but I am closer than you.
    Dec 2006
    Ok, so here's the next question.
    Oh, sorry...
    OK, SO HERE'S THE NEXT QUESTION!!!! (that better?? :-)
    What's the recommended material to make this box out of? 1/4" ply, 1/2" ply, MDF? I was thinking of lining it with pink insulation foamboard in addition to the shag carpet - think that'd help? Also, should this be a 5-sided box (ie, open bottom w/ box just sitting over the compressor on the floor, maybe w/ foam weather stripping along the bottom edge?), or a full 6-sided closed box (such as with a hinged lid or side panel?)
    Thanks guys - this is going to be my Saturday afternoon project w/ the kids!
    Jul 2005
    MDF, make it five sided so it will sit over the compressor with a couple of strips of shag along the bottom rim, not weather foam. Have the power cord and air line come out through a shag lined notch. The reason I say this is that you want air to get in for the compressor and the shag is porous but the weather foam is not.
    Don't use the foam board it is simply a good reflector of sound. You could use acoustic ceiling tiles, the ones with the random tiny holes. The whole idea is that you want surfaces that are not smooth and not rigid. When the sound waves hit they do not reflect they are absorbed.
    Of course if you want to get really fancy go to a marine supply place and get the lead bonded rubber sheet used in the engine housing for boats; many $$$$ per square foot. Works like a hot **** though.
    Dec 2006
    Ah, good point - guess the compressor needs to get its air from somewhere, eh? <:-)
    Boy, if this works well, I may even make a little insulated box neighborhood or condo and try to quiet my shop vac, too!
    Thanks Again!!
  • Page 1 of 3 123 LastLast
    1. Help with clear finish
      By trooper55 in forum WoodWorking
      Last Post: 03-05-2009, 07:35 PM
    2. How do I clear my cookies?
      By CNCadmin in forum CNCzone.com FAQ
      Last Post: 10-22-2007, 03:33 PM
    3. Optically Clear Adhesive
      By ejlouis in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 07-24-2007, 05:05 PM
    4. Replies: 18
      Last Post: 03-25-2007, 10:21 PM
    5. Cook your chips to make more chips :)
      By ToMMY2ooo in forum Bending, Forging,Extrusion...
      Last Post: 09-07-2004, 02:38 PM
